SOURCE: cleaned oven now won't heat
Probably what happened is during cleaning cycle the oven overheated the tco (thermo cut off). This is a thermo-fuse that is located behind the control board. It will need to be replaced.
SOURCE: unable to preheat
You need to replace the temp. sensor. It's not reading correctly. These occasionally go when you use the self clean as the range gets up as high as 900 degrees. Replace it and it will solve the problem
SOURCE: burner wont light
there is a heat sensor with a little window mounted on the side of the round tube it maybe bad it closes when the ignt glows red
SOURCE: gas burner ignites upon start
try the spark section.......may be its not getting properly heated
SOURCE: Whirlpool R365 Large Burners won't work
The problem could likely be in the sockets that the elements plug in to. Over time, they lose tension and deteriorate. The replacement sockets are relatively cheap and easy to replace. If the connection ends of the elements are still in good shape, there is really no reason to replace the element.
