SOURCE: My thread is breaking when
MAKE SURE YOU HAVE THE RIGHT NEEDLE FOR THE THREAD YOU ARE USING, AND THAT THE SAME THREAD IS ALSO IN THE BOBBIN. CHECK UPPER TENSION, BY PULLING SLIGHTLY, IF IT'S TIGHT, LOOSEN THE UPPER TENSION.YOUR THREAD MAY BE THE WRONG SIZE OR TYPE FOR THE SPEED YOUR SEWING., and the needle your are using( sorry about the caps lock)
SOURCE: i need instruction and parts manual for juki
JUKI HOME SEWING DIVISION
8500 NW 17 th Street
Miami, FL 33126
Phone: (305) 594-0059
SOURCE: how to fix timing on a juki ddl-555
HI U WILL START UR ADJUSTMENT BY HIGHT OF NEEDLE BAR FIREST U WILL FOUND TOW SLASH ON NEEDL BAR THE HIGHST ONE FOR HIGH OF NEEDLE BAR BRING THE HANDWHEEL AT LOSET POINT DOWN AND LOSE THE SCREW FROM INSID AND MAKE THE NEEDLE BAR AT HIGH SLASH AND THE SECOND SLASH FROM DOWN FOR TIMMING NEEDLE BAR WITH HOOK AT THIS POINT TURN THE HANDWHEEL AT THE SAME DIRECTION UNTIL PLAD POINT FOR HOOK COMES TO SURFACE OF NEEDLE
SOURCE: Juki Sewing machine DDL-555. After 4-5 hours use feed not moving
hi ,
i am looking for needles for the juki ddl 555 industrial machine , any ideas
thanks
SOURCE: What needle type is used for the juki ddl 555?
Regular sewing machine needles. Choose the needle type and size according to the type fabric or thread being used.
http://www.euronotions.com/pdf/Schmetz_Sales_Guide.pdf
