Technika lcd 19dvdid-207 won't turn on. flashing red light
My technika lcd 19dvdid-207 won't turn on. the red centre bottom (standby?)light keeps on flashing. screen remains black, can't watch dvd. tried turning off at mains, still no joy. help please.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
if the blue lights keep flashing you have shorted parts inside. usually the inverter board have a shorted IC, try to remove the connector from inverter then try again..
if your blue lights lit replace the inverter which you disconnect.
Sorry to tell you this i have the same TV.I have just checked the manual it says TO count how many times the light flashes in 3 second intervals.Then turn the tv off and un plug it from the mains.Sorrry then you will have to ring the Sony service centre and explain the problem.
try a remote reset by pressing every single button on the remote starting from the very top left hand button and pressing every single button - if that dont work ring the helpline with your reciept and they can sort you out from there.
I have same unit (which works in my case) but the red light does not flash on 'Standby', only when it is seeking a station after pressing the red button on the remote.
my lcd screen is broken , i need a lcd screen for model no. SC 500172 , can i get it in india, singapore or dubai or anyother place and what is the cost.
Hi brendafoud, have you had this fixed as mine is the same and has been for months. It happened just after the warranty had ran out(typical). Bought from ebay and the people I got it from are not very helpfull. Have you got yours fixed yet?
