Yes, the Panasonic KX-T7667 phone and the Panasonic KX-TES824 PBX are compatible.
The KX-TES824 should be able to accommodate different handsets because it is made to work with a variety of Panasonic phones, including the KX-T7667 model.
You must connect the KX-T7667 phone to an available extension port on the PBX and configure it with the proper parameters using the PBX programming software or a web interface in order to add the phone to your current PBX system.
It's vital to keep in mind that the KX-T7667 is a proprietary phone made just for Panasonic PBX systems and might not work with other phone systems or third-party hardware.
Here are some guidelines on how to receive faxes behind a PBX system:
First, make sure your Lexmark X4270 printer can receive faxes when not connected to PAP2 and the PBX system.
Ensure that your printer/fax is connected to correct Phone port on your PAP2.
Advise the sender to dial your number so that there is a pause before dialing the extension number to your fax machine. They could insert commas between your fax number and the extension number. It inserts a delay of few seconds each. (e.g. 1234567890,,,,,,,,,,456)
Contact "Cisco" systems, and or "Speakeasy", they are both close to you, and I think they offer support for your phone systems, contact me back if this doesn't help, P.S., try going to the companyies website,and see if the have a "firmware download", it's not as hard as it looks, god bless
press "CL" dial 828 0000 dial the 2 digits for the year dial the 2 digits for the month dial the 2 digits for the day dial the day of the week(0=Sun,1=Mon etc) dial the 2 digits for the hour dial the 2 digits for the minute press "SPK"
example "CL" 828 000 09 05 06 4 12 00 "SPK" would set Wed 6th May 2009 12:00
hi! u call the vodafone customer service centre! and get therestriction code! and then you change the sim into 2630 and give the restriction number.
thank you..........
