Westinghouse LTV-17v1 17 in. LCD Television Logo
Posted on Nov 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power cord were can i find a replacement power cord for this westinghouse ltv-17v1 its kind of diffrent the supplier sent on but iot was the wrong one and they did not have the one i needed
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Nov 10, 2009
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3368736
Points
33650
Why wont my 46' westinghouse lcd hdtv turn on?
If it's not a fuse in the power cord, is it possible that there is an issue with the wall socket?
Failing that, I'd look into getting a replacement either by purchasing a new one or through a warranty claim
1helpful
My Westinghouse LTV-30W2 when i turn it on the screen comes on and go's black my power blue light still stays on with sound what is wrong with it?
Thats usually an inverter board issue. Replacing the inverter should solve the issue in most cases. You can get the replacement inverter board from www.tvcircuitboards.com
1helpful
Need original remote control for Westinghouse TV Model LTV-17v1 SL
If you want to buy its original remote control, contact the authorized service center for Westinghouse at your town.
I am looking for a replacement power cord for my westinghouse flat panel tv Modell #sk-32h240s
you should be able to get a universal at Parts express dot com
is it like a pc cord or the one like a laptop (mickeymouse) or like a portable stereo?
2answers
Tv turns off and dont want to turn on again
check outlet power by connect other device, check power cord if OK check then unplug tv and open the back cover and check power filter fuse power filter is the one that you hooked power cord if OK check power supply board fuses if OK check the power supply board for bad blown components .good luck
Loses electric
Get a voltage meter and see if you have 110-120volts ac at the outlet. If the lights and/or a bathroom fan have any feedback they could lower the voltage to your TV and it may have a low voltage safety relay that turns off the TV when low voltage is present. This happens in older homes. If this home is older this little problem may be telling you that the wiring in your home is old and in need of replacement. You do not want a fire.
2answers
On and Off
We had the same problem with our Westinghouse LTV-19w3. Has anyone found a solution? I'm thinking it is the power supply box and cord but haven't invested in a new one yet.
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
