Try downloading the Touchpad drivers, then you will have that option.
Get online
and got to www.google.com In the google search box type: "Dell
Support" (without the quotes and put your manufacturer name before Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Download and install the Touchpad drivers.
You can disable the touchpad once you have the touchpad driver installed.
Most times when it installs the touchpad will be at the bottom right
near the time. you should also be able to get to it in the Control
Panel.
win 7 driver has stopped working
uninstal the driver for the mouse , find the web site for the manufacturer of the mouse , get the download for that model and compatibility with win 7 , down load and run
win 7 os is no longer supported by Microsoft so driver bugs and other glitches are not being fixed
Hi! Welcome to www.fixya.com.
You can try to download the Alps driver in this Link;
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_PNT_PM_D410&os=WW1&osl=en&catid=&impid=
If nothing happens after reboot: Its definitely a hardware issue. You have to call out fo warrant department your manufacturer so it will be fix.
Hope this resolution fix the problem on your computer.
Thanks for contacting Fixya. Bye for now.
The touchpad driver for your laptop can be downloaded from Dell's support website. Since I'm not sure which operating system your laptop has installed, I'll give you some more detailed instructions for locating the driver:
Visit www.dell.com/support, and click "Support for Home Users."
Click "Drivers and Downloads."
Click "Select Model" and choose "Laptops," then "Latitude," then "D410."
Click "Confirm."
Choose your operating system (Windows XP, Vista, or 7) from the "Operating System" drop-down menu.
Choose "Mouse and Keyboards" from the "Category" drop-down menu.
Click "Download" next to the "GlidePoint/StickPoint" driver and follow the on-screen instructions to download and install the driver.
I hope this help you locate the driver you need. Thanks!
Whoa, whoa, whoa, before you jump to conclusions, try disabling your mousepad and try using a USB mouse instead. I have never heard of a virus that does something that stupid. And in the unlikely event that it IS a virus, you can just purge the virus, not reformat the laptop.
Sounds like a compatibility issue between your Dell and the Docking station. I would say make sure the software for your docking station is installed properly, and update the software before connecting again.
Dell Latitude D410 XP Restore Disk
Dell Latitude D410 XP Windows Restore Disk This
is an automated Latitude D410 XP restore disk. The Latitude D410
drivers are supplied in a special windows friendly format. This means
that your Dell Latitude D410 XP Laptop will automatically find and
install all the drivers for your system, with hardly any user
interaction. If you have installed a new windows operating system and
half of your Laptop just wont work (with errors like no sound no
internet or bad graphics) then this is exactly what this CD has been
designed to fix repair. You can also use this CD Disk If you just need
to return your software broken Laptop back to the factory setup. There
are also a lot of utilities and resources on this cd that you would of
found on your Laptop when it was new in its original new condition.
Normally you would need to independently download and install each
driver and often enough it will be the wrong one! If you already have
other drivers installed it can get very over complicated with device
drivers not loading showing errors (like code 10 device cannot start) To
make matters worse you end up with allot of older and newer revisions
of driver too.
With this driver recovery system all you need to
do is wait until the Laptop can not find the device driver it is
looking for and put this CD DVD in. Sometimes you may need to select the
DVD CD as the location for your driver. That really is all there is to
it.
Works every time! Guaranteed!
THIS CD DOES NOT CONTAIN AN OPERATING SYSTEM! YOU
WILL NEED TO INSTALL WINDOWS FIRST OR USE IT IN AN EXISTING INSTALL. This
CD DVD contains every driver you need for your Dell Latitude D410 XP
Laptop. You are buying an automatic system that installs every
driver onto your system with minimal user knowledge and interaction.
This recovery disk includes much of the original factory software and
utilities. THIS RECOVERY CD RESTORE DISKS
IS DESIGNED SPECIFICALLY FOR THE Latitude D410 Laptop Do not risk a
bad installation by using cheap generic alternatives
Some of the drivers you would expect to find on the CD DVD are listed
below but not all will be applicable to your Laptop and this list is
for example information only.
-> Every driver you need
for your Dell Latitude D410 XP System -> Network drivers ->
Network card drivers -> Drivers -> Most factory setup
software -> Mouse drivers -> CD rom driver -> CD rom
drivers -> Express PCI -> Display drivers -> Graphics
drivers -> Graphics drivers -> Chipset drivers ->
Chipset drivers -> Detonator drivers -> Download NVIDIA ->
Download sound drivers -> Sound card drivers -> Sound card
drivers -> Soundcard drivers -> Scanner drivers ->
Sound drivers -> Opengl drivers -> Printer drivers ->
3com drivers -> Dell Latitude D410 XP system restore drivers ->
Audio Drivers -> Aspi drivers -> Device drivers ->
Audio drivers -> Device drivers -> Motherboard driver ->
Motherboard main board drivers -> Video card drivers ->
Modem driver -> Modem drivers -> Modem dsl drivers ->
Video drivers -> Ethernet drivers -> Ethernet drivers ->
Wireless Network drivers -> Intel Wireless card drivers ->
Video drivers -> Radeon drivers -> Base device drivers
S3 drivers -> Windows drivers -> Card Bus drivers ->
Windows Dell Latitude D410 XP Drivers -> Windows device drivers ->
Broadcom drivers -> NVIDIA drivers -> OSBC drivers ->
PCMCIA drivers -> TNT2 drivers -> USB drivers -> WAN
LAN drivers -> USB drivers -> VIA drivers -> VGA
drivers -> Web Cam drivers -> ATI drivers -> ATI
drivers -> VGA drivers -> All your version of windows
drivers -> PCI bus drivers
Repairs ALL unknown
device drivers Dell Latitude D410 XP Restore Disk Restore
Disk FREE ADD ON 1 Depending on the age of your
system, we have also included our own emergency driver re-detect
software. This will remove and unplug all devices from your system and
re-detected every driver automatically removing old and duplicates. This
will in effect clean out the side of your registry that deals with
hardware. No other restore disk has this software and can claim to clear
your system hardware drivers. FREE ADD ON 2 Some of our
restore disks have an automatic system driver update included!
There are many applications that allow you to automatically update your
drivers. These applications scan your system and the automatically
download and update your drivers. We are rolling this feature out in
all our recovery cds over the next few months
TAKE OFF ANY
IMPORTANT FILES (BEFORE YOU DO A WINDOWS INSTALL) USE THIS RECOVERY CD TO RETURN YOUR Laptop TO THE
ORIGINAL FACTORY SETUP!
try to do system restore it might one of the windows update causes the problem, if fails check system bios compare it from the dell support site if its out dated download bios then flash.
error: could not find registry key madden 08
