Ipod is far better than any other player. now apple have launched 5th generation ipod which are still better than old ones, so if i had the money like you have i wont have wasted time
There is a version of this on Amazon. On an Album called The Mess I've made by Heller Mason. You can listen to a sample to check it's the same song. You don't need to buy the Album, you can just get the one track. It's available everywhere as its a download. The Mess ve Made
The iPod's shuffle feature lets you randomize playback of albums, songs or even your entire music library. You may also find this feature useful if you want to listen to forgotten tracks in your library or discover songs you haven't listened to yet. Disabling the shuffle feature will return playback of a song list to its standard consecutive order. You can enable and disable the shuffle feature at any time.
Navigate to the main menu. Select "Settings." Scroll to the "Shuffle" option. Select "Songs" or "Albums." If you select "Songs," the iPod Classic will shuffle the songs on whatever song list you listen to. If you select "Albums," the iPod Classic will play all songs of an album you select in order and then randomly select another album. Navigate to the playlist or album to which you want to listen. Play a song to initiate the shuffle. b> iPod Nano and iPod Touch Tap the "Songs" icon on your nano home screen. If you are using an iPod Touch, open the "iPod" application. Navigate to the song list, playlist or album you want to play. Tap the "Shuffle" icon at the top of the list to activate the feature.
You will need to connect it to itunes and then delete from the ipod while it is connected.
If your ipod is set to manually manage music and videos then you can manually select songs and albums and hit delete. This may take a while. Use the search feature to scroll quickly.
If your ipod is set to auto sync then all you need to do is uncheck the songs, playlists and albums from synchronizing. It will remove them from your ipod.
You need to drag the downloaded files INTO iTunes to get iTunes to catalog the files. Once they are in iTunes you can sync to your iPod.
-=/ Daft Tech /=-
No. iTunes, Rhapsody, and Amazon (and others) allow individual song and album downloads.
Individual songs can go for about $0.99 each. Some subscription services charge less for individual songs. Which is better depends on how often you want to download.
Hi there, the problem comes from the tags attached to your media files. You must tag your files with the appropriate cover art for them to appear correctly. There is an application available for free that can do this for you: http://www.mp3tag.de/en/download.html
Once you have installed it, run the program. In the program, click File/Change Directory Select the folder in which you've got your music files and it will open the folder up for analysis. Preferably, you should group your songs by album to make the process easier for you. You select the songs from the list( for multiple songs, hold Ctrl while selecting) and then click on Tag Sources/Amazon.com or any other present website and use the search engine to find the appropriate album for the songs. Note that you can not search for multiple albums at the same time. Tags can be done per album. Hope this helps, Regards
Yes - instead of dragging an entire playlist or an entire album onto the GoGear, just go to the Sync tab in Windows Media Player and drag the individual song that you want to transfer. The player also has several play modes - repeat, shuffle, etc. - shuffle will give you a certain degree of randomization.
1. Have you tried charging your Ipod from another source other than the computer? Maybe a car charger for an Ipod or a kind that can be plugged into the wall. Ipod chargers are very inexpensive. 2. If that doesn't work try rebooting your Ipod with your Ipod program you were given to manage your Ipod.
3. Make sure that when downloading songs that they are Ipodcompatible, meaning that they are mp3 ready. Before downloading a song you should be able to see the credentials the song has for downloading. Most of the time if the format cannot be changed to being mp3 ready, most likely the song won't convert to your ipod.
I'm pretty sure you can't do this. At least, I haven't figured out how.
One thing you can do is make a playlist in itunes and drag several albums into it. Then your ipod can play the whole playlist. But this requires some forethought, since you have to set up the playlist on your computer.
Another thing you can do is create an on-the-go playlist right on your ipod. Here's how:
1. from the main menu, click music, then albums 2. scroll to the first album you want in your playlist 3. press and hold the center button until the highlight blinks. don't go into the album; you're pressing and holding on the name of the album 4. scroll to the next album you want in the playlist 5. repeat step 3 until you've got all the albums in your playlist that you want
Now, go to the main menu and press music, then playlists. Scroll all the way to the bottom and notice that you have a new playlist called on-the-go. If you go into it, you'll see that it has all the songs from all the albums you selected.
If you scroll past all the songs, you also have options to clear or permanently save the playlist.
Now you can play all those albums by selecting the playlist.
Again, it requires some setup, but it does enable you to play multiple albums without interruption. A nice side-effect of this method is that you can choose the order, whereas an automatic next album feature would play them in alphabetical order.
(FYI, you can add individual songs to an on-the-go playlist as well.)
And one final option: If you go to Music - albums - ALL, you can press play and it'll play your entire iPod in order. You can scroll to any song you want to start on, but you can't really scroll to the exact album you want to start on -- unless you know where to find the first song on that album.
I know that all three options are available in the latest iPod software. If something's not working for you, you may need to update your iPod's software through iTunes.
