Symantec Client Migration 3.0 Add-On to Ghost Logo
Anonymous Posted on Jan 07, 2008
Why restore ghost image
Ghost image burn my CD .
restore anther system why restore
boot in 98 cd , next insert the ghost cd restore image .
why resote ghost image
plz tell
Anonymous
Level 2:
Novelist:
Scholar:
  • Expert 108 Answers
  • Posted on Jan 27, 2008
Anonymous
Expert
Level 2:
Novelist:
Scholar:
Answers
108
Questions
Helped
56009
Points
141
You will need to restate your problem in better english.
How to reset my laptop with a sandisk cruzer 8GB
If you have a problem with operating system, there are many solutions;
1. Repair operating system with Windows Boot able CD, or flash drive boot able windows.
2. Reinstall operating system with Windows Boot able CD, or flash drive boot able windows.
3. Using system restore.
Restore to date when system in normal condition. How; press START - All Programs - Accessories - System Tools - System Restore - Choose a different restore point - Next - select date when a computer in normal condition - Next - Finish. Wait until the process is complete - Restart.
4. Using image backup. You've been backing up the system, and save Them as image files. By using the backup image, system damage can be fixed. How: click START - Control Panels - System and Security (Back up your computer) - Restore - select image file you've ever created, and you save on your hard drive - Next - Wait until the process is complete - Restart.
From above solution, solution no.3 and 4, is the most easy and fast
I hope this information useful
3answers
How to do system restore on asus laptop
Go to your start menu and in the search field type in system restore. Click the program and follow the on screen instructions.
1helpful
How do I do a full system recovery on my acer 4520? I want to set it back to when I first bought it.
It can only be done when you have created a Restore point when you first bought it.If that is the case,Under accessories,you will find system tools and then System restore.Select the restore point you have created ealier and finish the wizard.That's it.
If your COmputer is not able to boot due to some error then Download "Hren's Boot CD",you will be able to restore your system with that CD by booting your system with that CD in CD-ROM.
Here is the download link for "Hren's Boot CD".
http://d2.hirensbootcd.net/Hirens.BootCD.10.1.zip
Download the files and burn the ISO image in a CD and boot using that CD.Hiren's Boot CD contains many tools to recover data,repair a system,driver backup and what's not.
If you are not satisfy with the restore then you can even backup and important data and go for a new installed.
This time don't forget to create a Restore Point after finishing your installed.
How to restore my laptop
If your system is still running and you can work,and for some reason you want to restore it then
Click Windows Button
Select "All Programs"
Select "Accesoories"
Click "System tools"
Click "System restore"
Then just follow the wizard.
That's it.
If you can't boot and want to restore the system to a restore point that you once created then
Download "Hiren's Boot cd"
Here is the link    :  http://d2.hirensbootcd.net/Hirens.BootCD.10.1.zip
Burn the ISO Image in a cd and boot from cd rom.
you will be able to restore your system and more over you will have access to lots of recovery,repair and maintenance tools.
Describe your How to solve my Hard disk bad sector Problem
Easy solution would be to format and reinstall your operating system this will mark bad sectors and prevent your system from using those sectors... or follow the sets below if you really want to attempt to fix them
If you are familiar with burning images you can download the Hiren Boot CD image, burn it to a CD and then boot from it.
How to Burn image files http://pcsupport.about.com/od/toolsofthetrade/ht/burnisofile.htm
Hiren Boot CD download http://www.hirensbootcd.net/
Once you have your Hiren CD Insert into your computer and boot from it If the CD did not boot make sure your Boot order in BIOS is set to CD/DVD as the first boot device Generally you press Del F1 F2 or F10 to enter BIOS when the comes first starts to boot Look for Boot Priority or something similar to that and set CD/DVD as 1st device
Ok once in the Hiren CD menu (text menu) goto Hard Drive Tools followed by HDD regenerator This process can takes days and may or may not work
Please comment if you need further clarification or assistance
Thank You
1helpful
I want to change the HD from 40Gb to one with more capacity but I tried to make a ghost image in a 120GB and 160GB HD but the bios don't recognize it and only can see in the screen a simbol _ flashing.
Not sure which software you are using for making the ghost image. Lets say its "Acronis".
First, you will need an USB hard disk drive to store the image on.
Next, run the boot cd and choose backup.
Send it to the hdd.
If it was successful, remove / replace your hdd.
Run the boot cd again but now choose "Restore". Locate your image and then wait.
Hope this helps you. Norton Ghost is a bit different.
5answers
No WindowsXP, corrupt file windows\system32\config\system
Sad to say but alot of the computer manufacturers send Windows install/restore disks that are basically hardwired to the original hardware setup. The only real solution if you cannot install over your old setup would be to purchase the full version of the Windows o/s you want to install. Hope this helps & please remember to rate my answer. Thanks.
Restore the dell system to original configuration
insert the norton ghost cd and restart to boot off the cd. Then click advanced recovry tasks then select utilities select map network drive select drive letter then select the image to copy to the drive.
Mine is norton 9.0 so if you have the newer one it will be different
Please don't forget ratings
Ibm thinkpad T40 Hard Drive change out
After fdisk and format you need to ensure that operative system is installed into yor hard drive. Using ghost you restore the image disk by booting from ghost image CD if you made a bootable image disk. Ensure Bios is set up to boot from CD.
If you used Norton Ghost ensure you captured the image of full bootable original hard disk drive for same computer. If it does not boot after restoring ghosted image, than the image it is probably not complete. If hard disk image is not good, easiest thing to do is using Windows install CD to installl again operative system, then you eventually restore ghost image.
Ghost array0 over to newly setup array1 problems
I should assume the CD drive is SCSI? What sequence is it set to come up in? Set it at 2 if possible. Have you checked, or better yet replaced the CD drive? Will it boot with ANYTHING else?
That Hiren's CD is not uuummm, kosher? People having problems booting with it and all, plus the utilities may not have full function anyway. No matter what, you will need to f/disk the destination drive. You will still need the CD drive to install the program too.
Backup software will still make an exact copy of your drive also. You might want to consider a little better product, especially concerning disaster recovery. not to get off topic but, a quote from J. Bolton on backup & recovery
"What will you do if a user overwrites a 1000page doc with a blank file with the same name? What will you do if one of multiple server apps goes bonkers? If the mainboard dies how will imaging get your system back? Do you stock a spare board so the image restore will work on the exact same hardware? After a system crash, Acronis True Image Enterprise Server allows you to perform a full system restore, a bare-metal restore or just a restore of individual files and folders.
Complete system restoration can be performed to an existing system, to a new system with different hardware or to a virtual machine. You could setup a whole new system and dump the image on that.
Top Symantec Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
