Maytag front load washer. When the drum is rotated after the laundry is finished, I can hear water sloshing in the machine. Also, the inside of the machine smells musty, as though the water is trapped in the machine.
Is there a broken seal and how can I eliminate the smell.
The water in the unit is normal, to kill the smell when you are done doing wash for the day dampen a rag with bleach and whip down the door gasket. You can buy a cleaner called "afresh" it works as well. If your unit is a neptune check with maytag it might have a recall on the door gasket for growing mould
