Mitsubishi VS-60705 60" Rear Projection Television Logo
Posted on Nov 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Television turns itself off after being on for about 10 minutes
My 9 year old Mitsubishi (vs-60705) Television turns itself off after being on for about 10 minutes. It will not turn on until I unplug it for about 30 minutes. Can this be fixed?
Doug Warne
Level 2:
Scholar:
  • Expert 58 Answers
  • Posted on Dec 16, 2009
 Doug Warne
Expert
Level 2:
Scholar:
Answers
58
Questions
Helped
30967
Points
143
Run the diaginostic that you find in the pdf user manuel...1st
1helpful
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Mitsubishi VS-60705, Turns on/Turns off.
Unfortunately you will need an experienced TV tech.
This unit will need 2 ICs STK392-110 for 1 has shorted and caused damage to the 2nd as a result blowing 1 or 2 pico fuses in the power supply.
It is an involved job and may be somewhat costly depending on the pricing in your area.
Hope this helps Normal 0 false false false MicrosoftInternetExplorer4
2helpful
Vs-60705
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility that works on rear-projection TV's should be able to repair your set. I bought the set on Jan 1, 2000. Coming up on 9 years and the set works like new.
Tv problemsMitsubishi VS-60705 60 in....
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility facility that works on rear-projection TV's should be able to repair your set.
1helpful
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Mitsubishi VS-60705 Horizontal Hold issue. Hi, I have a projection TV thatis about 7 years old. I moved and recently hooked it up after sitting for 1 year. It worked great. 2 weeks later I turn it on and...
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB.
4helpful
2answers
Mitsubishi VS-60705
I have a Mitsubishi VS-60705 and the picture flutters vertically and horizontally i need to be fixed
5helpful
2answers
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Television keeps turning itself off.
There are two integrated circuits called convergence amplifiers , they need to be replaced. this is a common failure on this model. the cost to replace with parts is around 250.00 dls depending on the tech. if you need more help let know thanks
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
