Question about Toshiba SD-1700 DVD Player
After inserting disc in player, get message: disc loading
After inserting disc in player, get message: "disc loading" but nothing happens. The disc does spin. Am using in Normal mode.
    Guru:
  • 214 Answers
Your dvd are not recognized your cd
Posted on Nov 12, 2009
6ya staff
SOURCE:
When I load a dvd into the player, after a while it says "no disc" and nothing plays.
Do the "bad" disks work on some other DVD player?
Or, do the "bad" disks work on some computer with a DVD drive?
Dirty disks with lots of greasy fingerprints?
Feb 16, 2014 | Sanyo Televison & Video
Disc doesn't spin
Hello
Check whether the disc inserted into the player spins. If it does not spins, replace the sled motor.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
DVD spinning slow and get a 'No Disc' message
The problem sounds like the spindle motor is about to go out completely. If a disc does not spin or does not spin at it's proper speed the optical lens reading laser can not read the disc and you get a "no disc", or "disc not recognized" error message. On average a dvd will spin 3 times faster than a regular cd will. The following pictures will show you what these components look like.
Check around your local area to find what a service technician will charge to replace the part. On average it will usually cost between $60-90 dollars most of which is labor.
I hope this gives you some idea of what the problem is and how to solve it.
If you would not mind, please rate my help. I would greatly appreciate it. Thank you
Feb 07, 2010 | Televison & Video
Discs won't play.
please change laser unite then solve your problem
Jul 16, 2009 | Sony DVP-NS575P DVD Player
Sony DVD player reads no disc after inserting disc?
Its due to faulty Laser Lens/head. Try cleaning it by cleaning CD. If still the problem persists, contact near by service center.
Mar 13, 2009 | Sony DVP-NS715P DVD Player
Ps3 not reading cd/dvd/games/blurays
hi...
The inside of the disc player is probably dusty. Video game consoles are notorious for gathering dust. I've fixed dozens that way. Cleaning inside the drive
Jan 15, 2009 | Sony Playstation 3 (PS3) Console
Disc Error/no disc messages
there is a strip that connects from the body of the lens to the circuit board take it off and replace it this will fix your problem you can contact dalbani in miami florida.to purchase the strip
Feb 17, 2007 | NAD T512 CD Player
Bad disc or insert disc problem
If you are using a copied disc try a real one. But this model of DVD Player is made so cheap. it sound like the laser assembly is bad or the motor that spins the disc is stuck or going out. If you are good at electroninics you could take the lid off load a disc and see if it spins if not give it a spin clockwise and see if it takes off. You probably should replace unit for price of a new one.
Dec 31, 2006 | Cyberhome CH-DVD 300 DVD Player
DVD Player stops in "Loading..." mode
1. Check that disc is encoded for your geographical region. A disc from Europe (Region 2) will not play in a North American (Region 1) player. 2. Turn off player with disc inserted, unplug temporarily from wall outlet, plug back in and turn back on. 3. If your player has a transportation lock (usually a plastic screw on the bottom of the unit), make sure that it is not engaged. 4. If you have an older player, check with the manufacturer to see whether an update to the firmware is available. Many newer DVD titles with lots of special features are famous for causing problems on older players. if nothing helps, call for service.
Sep 12, 2005 | Cyberhome CH-DVD 300 DVD Player
Toshiba SD-1700 DVD Player Logo
477 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
