Question about Bausch and Lomb Bausch & Lomb Hunting Elite 4200 Riflescopes Matte Finish With Sunshade Pow
FOGGY SCOPE 4200 ELITE BAUSCH AND LOMB
WHAT CAN CAUSE THE FOG IN MY SCOPE IT NEVER HAPPENED BEFORE
    President:
  • 2,702 Answers
The seals have leaked and some water has found its way into the scope,, it needs to be striped down and new seals fitted all the glass cleand and a regas,,, not cheep
Posted on Nov 17, 2009
6ya staff
SOURCE:
Which is the best waterproof spotting scope?
Sometimes, nature can spoil your recreation. Rain and fog can be a major hindrance to your activities. But considering this issue, OXA spotting scope is both waterproof and fog proof. You can enjoy to the fullest and without any worries under any situation. So If you want to take a waterproof spotting scope, I suggest you take an OXA waterproof spotting scope. OXA is such a that types of spotting scope which can be transported effortlessly. The scope is very light and has durable magnalium framework and fitting protection. The OXA rubber armor provides the maximum protection of the scope which is the best quality framework than any other scope.
Mar 20, 2018 | The Optics
Which is the good spotting scope for higher amount of light?
Bushnell Trophy Xtreme Spotting Scope
Overview
Bushnell Spotting Scope has extra power for extra range; its BaK-4 Porro-prism design delivers magnificent clarity in a traditional design. The multicoated optics ensure maximum light transmission for the brightest and take the images more colorful and clear. If you are searching Bushnell Scope that can be used for different activities, you should consider Bushnell Trophy Xtreme Spotting Scope Review.
The highly refractive BAK4 Porro prisms diminish spherical deviations for increased edge-to-edge sharpness and help progress depth of view. This combination of optics and coatings creates a spotting scope that produces clear, bright, highly contrasted images with the exact color transmission.
The rubber-armor structure stands up to demanding use. This scope is 100% waterproof and fog proof for wet hunting conditions. It also Comprises compact tripod with window mount, compact soft case, and waterproof hard case.
Specifications
  • Brand:Bushnell
  • Viewing Configuration:Straight
  • Magnification:16-48X
  • Power Variability:Variable
  • Objective Diameter:50 mm
  • Close Focus Distance:25 feet
  • Length:13 inches
  • Weight:31.4 ounces
  • Field of View:125-60 feet/1000 yards
  • Eye Relief/Exit Pupil:16 mm/ 3.1-1 mm
  • Optics Coatings:Fully Multi-Coated
  • Glass:BaK-4
  • Focus System:Focus Knob/Single Focus
Feature Analysis
  • Porro Prism Lens
    Though many optics producers keep on trying to transform roof prism lens, Porro prism lenses are more affordable and light-efficient. These Porro prism lenses can display images with better contrast than roof prism variations. This is how Bushnell Spotting Scope is more reliable and affordable for its high-quality performance.
  • 20-60×65 Zoom Magnification
    The wide range of magnification allows user flexibility for long-range view finding. You can observe details with 65x zoom for long range objects. But, you can still enjoy an increased field of view with 20x zoom. This is used when separating the areas for closer zoom viewing later on.
  • 65x Lens Light-Gathering Capability
    This advanced magnification lenses can light gather at long distances. The Bushnell Trophy 20-60x 65mm Waterproof Spotting Scope resolves this issue by designing 65x zoom lens in a way that brings 17% more light than most high-zoom lenses.
    If you fully read Bushnell Trophy Xtreme Spotting Scope Review, it will support you how to setting zoom for longer distances images.
  • Waterproof Construction
    When you go out in nature, this waterproof construction anticipates you about rain or even snow. It is pretty obvious that any liquid that leaks into your scope will detract from the overall image. But many people do not consider the effects of concentration on the inside of the lens.
    This spotting scope is actually water and fog proof not only for outside moisture but also prevents lens fogging from risky temperatures.
  • Fully Multi-Coated Optics
    The multi-coated lenses prevent any reflections in the glass that can delay your view. The sunlight at certain angles can cause reflections from water or wet surfaces that prevent the clear view of the images. That is why; Bushnell uses multi-coated lenses to remove any kind of reflection.
  • Well-designed Equipment
    The tripod often needs to hide from animals, and the scope cases also need to protect their insides from both jostling and the outside elements. The Bushnell Trophy XLT comes with both a hard-side case and a soft side case. The hard side case protects you from outside damage and a soft-side case protect you from a bumpy road when you are riding.
Mar 18, 2018 | The Optics
Which is the best spotting scope under $ 250?
Mar 17, 2018 | Firearms
Scope is fogging up and appears to not be clear. Tasco 3x16
Fog in the scope means moister inside. You can try and dry it out, take the rear lens off and using a hair drier heat the tube and the lens separate. Do not blow air inside it may damage the cross hairs. You can try and pressurize the tube so it will not happen again. You will need a large clear zip lock baggy the biggest you can find. Once your scope has been heated with the hair drier. Put the scope in the bag. and try to draw out all the air inside. You can use a Vacuum cleaner. if you get enough air out you can reinstall the adjustment lens on and the tube should stay in a vacuum for a season or two. You can also put vasiline on the threads to help seal the vacuum. You can also try to use gas, you can use gas from a paint ball gun cylinder to pressurize the scope. Put the scope in the bag pressurize the bag and reassemble the scope with the gas inside.
Jan 09, 2011 | Tasco Optics
Scope is a 1995 year model. Optics got blurry this season.
could be the the eye sight adjustment piece at the front of the scope got turned some how , try turning the lens piece to focus ... If it looks like fog , it is probably the nitrogen has leaked out, you will have to return it for repair..
Dec 30, 2010 | Tasco World Class Rifle Scope 3-9x50 Matte
Conquest scope has condensation on the inside any ideas
You don't see too many good scopes fog up, I would send that one back to Zeiss, you paid enough for it, they should stand behind it. If it was a simmons, I would tell you to put it on a heater for a week. But the Zeiss is in the top 10. Hope this helps.
Apr 07, 2010 | Zeiss 6.5-20x50 AO MC Conquest Stainless...
Scope is fogging up
Either use an anti-fog wipe on it, such as Scope Dope... or don't breathe heavily on your lenses!
Jan 01, 2010 | Tasco Hunting World Class Scopes Standard...
Rifle scope fogging
You can try to clear this your self. You will need a good sized clear plastic bag, say kitchen trashed can size. You will need to get your hands on some nitrogen or you can also use carbon dioxide. You will need some good electrical contact grease or Vaseline will also work. Take the focus lens off your scope, let it dry out. Now ck for any o-rings and try to find new if you can, put the grease on the screw threads.Put all the scope parts in the bag and pump up the bag with your nitrogen and tie off the bag but leave room so you can screw the lens back on once it has set for a little bit in the gas. This should let gas stay inside the scope so no moisture can get back inside to fog it up. Try that, sounds crazy but it will work.
Dec 03, 2009 | Optics
Fog light bulb replacement
This bulb can be replaced without removing the washer fluid reservoir. There are 3 screws that go through the bottom edge of the bumper cover into the right inner fender guard. Remove these screws and pull the inner fender down to gain access to the back side of the fog lamp and remove the bulb.
Nissan Scope Technician- 10+ years experience in Nissan dealership.
Nov 04, 2008 | 2003 Nissan Murano
Bausch and Lomb Bausch & Lomb Hunting Elite 4200 Riflescopes Matte Finish With Sunshade Pow Logo
391 people viewed this question
Top Bausch and Lomb Optics Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
M J U
Level 1 Expert
Are you a Bausch and Lomb Optic Expert? Answer questions, earn points and help others
