Washing Machines Logo
Posted on Nov 12, 2009
Kenmore washing machine didn't spin @ end of cycle
Kenmore 600 washing machine didn't spin the clothes at the end of the cycle last night. tried a different spin cycle and it worked. the next load it wouldn't spin on any cycle.
Luis Soto Jr.
Level 1:
New Friend:
  • Contributor 26 Answers
  • Posted on Nov 12, 2009
Luis Soto Jr.
Contributor
Level 1:
New Friend:
Answers
26
Questions
0
Helped
7015
Points
79
If you tried a different cycle and it worked this means that the timer is probably bad on the main cycle that you use. If the machine does not spin on all cycles, then please check out the LID SWITCH.
How to just run the spin cycle?
https://www.manualslib.com/manual/85754/Kenmore-29522.html#manual
Kenmore 600 Series Pdf User Manuals. View online or download Kenmore 600 Series Use And Care Manual. ... Kenmore Washer Use and Care Guide.
Probably the worst washing machine manual I have ever read!
Try this.
Put your wollens in the machine, set for cold water, Woollens Cycle and your 'Soak' detergent. It will agitate a bit, and as soon as it stops filling, turn it off.
After say 20 minutes. Then Move the dial to Spin, and pull the knob out. It _should_ pump out and spin.
Kenmore 20422 leaves water and clothes soaked after spin cycle
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
Initial thoughts point to one of two places.
1. It's possible that your pump and/or hoses are clogged.
2. It is also possible that the "Motor coupler" between the motor and transmission is worn and cannot provide full power to the tub when agitating.
See the following illustrated descriptions of how to access the pump and motor coupler.
If either is bad or worn, they aren't all that expensive.
I doubt that the problem is the motor since the machine will agitate and spin.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=1c39a06ff50bcc5c8439ed37e02f402a
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
2helpful
2answers
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
At end of wash cycle, water won't pump out of washing machine
You need to try to put your clothes in the scale to messure the right amount of clothing you will be washing at the time.
5helpful
2answers
Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
3helpful
Wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Top Washing Machines Experts
john h
