Epson Stylus C60 InkJet Printer Logo
Posted on Nov 12, 2009
EPSON C60 RED LIGHT FLASHING ON CENTRE BUTTON CANT STOP IT
Davecapt
Level 1:
  • Contributor 26 Answers
  • Posted on Mar 19, 2010
Davecapt
Contributor
Level 1:
Answers
26
Questions
0
Helped
10694
Points
33
Shellnbarry, As I stated in a previous post the red light flashing means an ink cartrdge is low but not empty. When the red light stays on it means an ink cartridge is empty. You can continue to use the printer until the red light stays on.
Red light flashing
Power off your printer, open the cartridge lid; take out the cartridge and put them back again.
Power on your printer and check whether the red light still flashing?
For further assistance, you can also avail our technical support services by visiting our website: http://www.vtechsquad.com.
2answers
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
4helpful
2answers
(Epson Stylus C60)red light blinking, says contact
keenepadgl, "Contact service engineer" for a C60 used to be all you could do. Now you can go to SSC Service Utility and download it. But the red light blinking (if that is all that is happening) simply means you have a ink cartridge that is low but not empty. If the red light stays on, then it means a ink cartridge is empty. By downloading SSC Service Utility you can solve about any problem you have with a C60. That's what the "Service Engineers" use. Check out the protection counter reset in SSC, that is the main reason people had to send their C60s to have serviced., and what service would do is press the reset button in SSC program. NOTE: I would go to inkmizer and get some cleaning fluid instead of nail varnish remover.
RED LIGHT WONT STOP FLASHING
shellnbarry, The red light flashes when an ink cartridge is low (but not empty). You can continue to use the printer until the red light stays on meaning an ink cartridge is empty.
1helpful
My Epson is printing pages in code and will not stop and the green light is blinking and the red is staying on. We put in new ink cartridges today.
zark4, The green light flashing means you have print jobs waiting to be printed. Don't Turn Off The Printer When The Green Light Is Flashing ! If you have paper in the printer, the red light means you have an empty ink cartridge. Because both things are happening at the same time, here's what you need to do. First click start. Click printers and faxes. Double left click the Epson C-60 Icon. Left click Printer and click Cancel all documents and click yes, then exit. Remove and reinsert your new ink cartridges to make sure they are seated correctly. After you have done this and the printer finishes the automatic charging of the ink cartridges, the lights should be back to normal. Green light on.
1helpful
Green light flashing Red light on
with regards to the status of the lights., its either the cartridges that you installed is not recognized by the printer's print head or cartridges are defective.
try these steps:
if all the inks are new take them out and get an eraser and rub the small chip gently so as to clean the contacts of the chip ( don't touch it with your finger ) reinsert the cartridges in the printer and allow it to charge.
14helpful
2answers
Epson C60 Printer: Green light and red light flashing
If both lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C60), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
If this solution helps you, please rate it; if it doesn't, please provide further information by posting a new comment.
Just re-installed the driver and then the Epson C60 printer/scanner. Doesn't print is #1 problem.....shows the printer as "ready", but doesn't print. Other problem is need to change a color cartridge and...
Hi
Have you tried pressing the maintenance button, press and hold it up until the cartridge holder moves to the place where you can change the cartridge. are there any error lights as well on the printer? red or flashing light?
Hope this helps
No response
If you´re pressing the ink button and the carriage still does not moves is cause the level of the ink is low, but it does not finished yet. You must use the printer more, then the red light will stop to blink and hold on, then you´ll be able to change the cartridge.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
