A common weak spot on most laptops is the DC power jack. If someone trips on the wire while you have the power adaptor plugged into your laptop, chances are that the power jack will get damaged.
On most laptops the DC power jack is soldered directly to the motherboard and there are only three or four small pins holding it in place. Unfortunately that makes the power jack quite weak. Any sideways pulling of the DC power cord while attached to the laptop will usually dislodge at least one of these pins, breaking the solder around it. Modern laptops use quite a lot of power, from about 70W to 120W or even more. The bad electrical connection from the dislodged pin will cause sparks and heating that will eventually burn a hole through the motherboard and can even be a fire hazard.
The usual signs of that are:
- The battery is not charging properly or stays at half charge despite that you have been using the power adaptor.
- The screen flickers (the brightness is changing) while the power cord is plugged in. This is caused by the laptop switching between DC power (screen is brighter) and battery power (screen is dimmer).
- The DC plug gets hot after a few minutes of use and may even smell of burning.
- There are "scratching" sounds coming from the DC jack.
You need to take the unit apart and check/resolder the DC jack on the system board.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
