Olympus FE-310 Digital Camera Logo
Anonymous Posted on Nov 13, 2009
I put fresh batteries in the camera & it's says battery empty,change batteries again & it still says batteries empty. i believe the battery door is not closing right.
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Nov 19, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
9384
Points
11
Its not your camera..
all Olympus FE 310 cameras have that problem
the manual for the camera says that the best batteries for the camera are the Panasonic Oxyride ones.. ive reasearched them and read reviews.. all the customer reviews say that theyre the best for cameras that die out quickley (like the Olympus FE 310)
I personally havent tried them yet because i dont know were to get them but you should look into it.. see of you like them.. they might be the right ones for your camera..
Testimonial: "thank-you, i will look for those batteries. hopefully they will work."
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Dec 31, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
9613
Points
6
All these posts are related to a power problem with this camera. In short, it requires a higher voltage battery than the ones you find everywhere.
After wasting many hours searching for someone that had the recommended Panasonic 1.7v batteries in stock (versus the standard 1.5v battery found everywhere) and trying a couple of suggestions to improve the battery / terminal contact, I decided on trying the solution provided by blackduk on this thread (http://www.fixya.com/support/t1595282-olympus_fe_310_battery_problems), with very slight modification.
First I just placed the capacitor across the terminals and closed the battery door. It increased my shots per battery from about 10 to about 50. (Not great, but probably because the connection wasn't even as good as a 'cold solder'.) But it was enough of an improvement, and as the battery door never closed properly with this 'fix', I decided to go with soldering. Afterwards, I went through two battery sets in testing. Both times I got in excess of 300 images, with flash on all photos and zooming in and out while the flash charged!
Accessing the terminals was easy. Just remember, it is the thin front panel of the camera that comes off (after removing 6 screws). Facing the lens, the 4 long screws need to be returned to the right side and bottom of the camera. The 2 short screws need to be returned to the left of the camera. Measure and clip the wires on the capacitor. Have a hot iron. (Initially I didn't have it hot enough and singed the plastic trying to get a good join. Hotter for a shorter period makes a better solder and won't melt the plastic.) Tin the terminals. Grip your capacitor wire with needle nose pliers, hemostats or some other heat-sink when soldering. Do it. (Mine is far from a pretty piece of work, but functionally it is perfect - and you can't see my goofs once the face plate is back on.)
I ordered the capacitors from Talon Electronics. I got Axial, instead of Surface Mount, with the same specifications blackduk provided. A quantity of five, Item Number TNC0019, 2.2uF 10V Molded Axial Tantalum Capacitors, cost me $7.23. That included shipping (they were .25¢ each). I ordered through www.talonix.com.
Good Luck,
Andrew
What does battery exhausted mean?
It means the batteries are drained or empty. Put in a fresh set of batteries, or recharge them if you're using rechargeable batteries.
1helpful
Fuji HS20EXR wont turn on after turning off
A defective rechargeable battery caused this on my camera, not sure about the blue haze though. Make sure battery is good or use fresh alkalines.
Empty batteries
Your camera may have been in wet conditions. So "short cut" may have been occurerd. Please firstly put your camera in a hot and dry room. Wait at least one day. After that process. Try again to use with brand new batteries. It will work I think.
6helpful
2answers
Polaroid one 600 instant camera how to change battery
Change the photo pack. That's where the battery is located, you get a fresh battery with every pack.
Note that all remaining photo packs are now beyond their expiry dates as production ceased last year so many will have flat batteries or batteries with insufficient charge to last for the full ten shots. There's no fix for this: all that can be done is to rig up an external battery pack but there is no standard kit for this so it's very much a DIY project. the camera draws 4.5v and the standard battery was 6v when freshly manufactured.
1helpful
Fresh batteries, clear playback, but still won't take a picture
Change the teeny date/time battery--dig it:
http://www.fixya.com/support/t2374899-change_batteries_message_even_new_nimh
I was all set to send my camera off to canon for repair when I happened across that solution. I don't have a replacement on hand, but just removing that battery allows me to take pics again.
1helpful
Hi, I have a Nikon D300. First problem - The battery started showing empty / full / then empty again. Bought a new battery, worked first time, then the same problem empty / full / empty. Change the...
A capaciter in your camera is not working properly and is discharging your battery even when the camera is turned off (this is a cheap problem to fix but must be sent back to NIkon for repair
Dec 06, 2008 • Cameras
Battery Problem
the problem for the camera turning off or acting weird is the batteries. you need Alkalyne Batteries
Battery Empty
the little icon battery looks empty on the lcd screen? I would not worry about especially if your camera is taking flash pictures and lasting a good while....for my battery indicator on my two different cameras looks half charged and they high amp 2700ma. maybe its going over the mark. try putting in common batteries like duracell and see if it dont return to full indication charge.
3answers
BATTERY DISCHARGE
No repair for this one I fear. This seems as it has an internal short and this will not be repaired.
2answers
Battery problem
did you use comapny authorised battery if not go for it
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
