I have taken my first picture with new camera but it gives error message "write error check memory card". But the card seems fine and works in my old camera.
Hello Try removing the battery and the memory card for 1 minute then return them back. Make sure the battery is inserted properly. If that didn't work, try turning it on without the memory card.
Did you get any error message when you try to turn on your camera?
This is a problem with the memory card. I don't know why your camera is not giving an error message of some kind- it seems to know that it can't store pictures there.
Probably the first thing to try is formatting the card. There is a function in the camera menus to do this. If it won't format or gives an error when you try, then there may be an issue with the connectors in the card slot or the card may be incompatible.
Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
There's a slide switch on one edge of the SD card. Slide it away from the contacts. If that doesn't work, there's a problem with the mechanism inside the camera that detects the switch position.
Well-not easily. It will not work through USB. An out-of-the-box camera only lets you access camera memory card/onboard memory. However you could connect the camera video-out socket to a PC with graphics card with video capture function. Some cards with video capture work with skype (check this URL: http://forum.skype.com/index.php?showtopic=41101 ) At the moment this seems to be the only easy way to use TZ3 as webcam.
Memory card likely has temporary(needs formatting) or permanent problems(needs replacing, common for off branded china junk).
First format the mem card on your camera by pressing center Menu button then scrolling down to the end of the menu to Format. If this does not work, and you have bought a Name Brand SD card; Sandisk/Kingston/Patriot etc, return it to place of purchase with receipt, or creditcard use to purchase it, and they will replace it.
i suggest you first try another card to check if the card or the camera is faulty. if it is the canera then it could be the sd card slot that is faulty. this will have to be checked by a qualified panasonic tech.
I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out Wikipedia.org for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others. http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Panasonic/Panasonic_Lumix_DMC-TZ3
