Hi I have a Panasonic TH-37PA20 with a 12 Flashing light problem. From what I have heard, this is something to do with a 5 Volts problem. Could someone confirm that and where should I start looking on the PA Board? No Resistors or capacitors seems burned out.
Thanks,
Phil
SOURCE: 42'' plasma panasonic viera model th-42px6ou wil
You did not replace the A board? These are the possiblities
P, A, GS, K
Visit the site named 'Electro-help' for more
details. Check this link and select the
site named above. View it in 'Flip card' option, which can be
selected from the drop down box menu by the [Sidebar] tag, at the left top left
corner of the display window. It will make search easy. Some times, the ads
attached with each posts both at the right and bottom, might help you to find
the availability of spare parts. There are more than 640 posts to different
brand TVs now. Will be updated daily. Faults and blinking codes; locating faulty board etc are described in detail. Pull up older posts there. You can narrow down the search for the faulty board. Normally 6 blinks indicates Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
Please dont forget to vote if you liked my answer
thanks
