SOURCE: i require an 165 deg . celsius thermostat T3 / TY60R
You can get one here
http://espressocare.com/Qstore/Qstore.cgi
Good luck
SOURCE: rancilio silvia
It more likely is the automatic boiler shut off if the boiler overheats. Just reset the boiler.
SOURCE: rancilio miss silvia dispenses cold water
If there is steam in the machine, the only other problem would be if the portafilter was cold and you are brewing into metal or glass demitasse that has not been heated.
SOURCE: Rancilio Silvia Espresso water flows too quickly about 7 seconds
SOURCE: Manual for Rancilio Silvia V3 (two water supply tubes - why ? )
Hi
The second one is your relief valve return water line. It just sets in the tank. Doesn't go anywhere.
Testimonial: "Fast and concise .Thanks"
