Are you using it for the first time? If so, connect a TV to the DVD output, follow the instructions to set the language. If the unit was functional and it happened recently, then unplug the unit, remove the top cover, inspect all the ribbon connectors are inserted properly (especially the ones with the ferrite beads). Be careful not to rip them.
To unlock, manually press and HOLD the open/close button & the stop button simultaneously, and HOLD them both down until the lock picture disappears. The DVD will eject when you press the open/close button.
To lock the DVD inside the machine, repeat the same step, and it will lock it inside.
