Im not sure if it wants a password but when I try to reinstall windows xp it say the HDD wasn't detected.Im not sure if it wants a password but when I try to reinstall windows xp it say the HDD wasn't detected.
You can't post conmments that contain an email address.
on some notebooks if you hold shift control then zero it should resset the bios passwaord to get back in.. serch the del site for your model nad it should give you tips on how to do it .. but i know for toshiba that is works remember contol+ shift +zero should reset pw.
dear friend i understood your problem there is nothing special to do just format your laptop pslb84-027025 becausethe problems you have to face is due to virus program attacks to your laptop some times an antivirus program unable to find the viruses so i suggest you to format your laptop.
NOTE:keep the back up of the drivers , or you don't have? just go to www.notebookera.com then select your device then download the drivers related to your device.
press Del or f1 or f2 or Home or Ins or end key...some of the PC/Notebooks BIOS is set to any one of the above keys...
so after starting PC press the key as mentioned above...
u may have to do hit and trial....and find the key that gets u to BIOS
then change the boot seq to foll
1 - CD Rom drive
2 - Floppy
3 - HDD, or HDD0, or HDD1 etc
Hi, If you are prompted for a password just after boot up and are unable to provide the correct password there is not much you can do about it. After 3 wrong trials the laptop will lock. The only solution to regain control of your(?) laptop is to take it to a Toshiba Certified Service Center to have the password removed, or changed. You may have to show proof of ownership.
It's probably actually a BIOS password. This can sometimes be removed quite easily by removing the dime-sized silver battery for the CMOS. For further information, check out this document.
10gb of RAM is not enough for Windows XP. You need to upgrade your HDD to about atleast 40 GB HDD Minimal... I'd recommend a new PC if you can get that to work out, but I understand the tuff economical times.. If you need any mroe help ..throw me an email at [email protected] I'll give you some bootable tools that may help!
1. At the BIOS password
prompt ("PASSWORD = "), press and release the following keys,
one after another: Ctrl, Tab, Ctrl, Enter The computer's response
should be: PC Serial No.= XXXXXXXXX
Challenge Code= XXXXX XXXXX XXXXX XXXXX XXXXX
Response Code= 2. Get
response code from your local toshiba support center Then follow the instructions the support guy will give you to unlock the laptop
Do a search on google for the Toshiba Password Removal. If you are enclined enough you can build your own parallel port key that will wipe the password out.
If you would rather buy a premade port key, search on eBay for something like this -
I found a schematic once online, a long while back when I had the need, and built my own out of spare parts in my shop. Worked great... only had to use it once for a customers laptop. But I still hang on to it just in case someone else comes along. There is also a USB version I believe.
