Sony PlayStation® 3 (80GB) Console Logo
Posted on Nov 14, 2009
PSP wireless connection error - time out while exchanging key
I have set up wireless network on my PSP. The router is configured to use WPA2-PSK-AES but the PSP had only WPA-PSK-AES as an option which I chose and it is timing out while exchanging the key and giving a connection error. Router is Linksys WRT54G2 Wireles-G . Can anyone help please?
1 Related Answer
Anonymous
  • Posted on Mar 15, 2011
SOURCE: have belkin.36e4 security
My Acer Aspire 5336 can't connect to a wireless with a WPA2-PSK security standard. What can I do?
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
1helpful
I need to make my connection secure
do the following
  • Change the network name (SSID) from the default name
  • Change the administrative credentials (username and password) that control the configuration settings of your Access Point/Router/Gateway
  • Enable WPA2-Personal (aka WPA2-PSK) with AES encryptionCreate a network passphrase that meets recommended guidelines
  • Enable WPA2 security features on your client device and enter the passphrase for your network
How do you write an ASCII network encryption key?
Hello. Wireless security strength depends on the mode of encryption you are going to use (WEP, WPA-PSK [TKIP], WPA2-PSK [AES], WPA-PSK [TKIP] + WPA2-PSK [AES]).
WPA-PSK should be enough to secure your Wireless network.
ASCII - Choose from any key available on the keyboardHexadecimal - Characters ( 0~9 and A~F)
  • Before setting up wireless security on the router, make sure the computer you are going to use to setup wireless security is directly connected to the router using an Ethernet cable(wired).
  • To setup wireless security on the router, access the router user by typing http://www.routerlogin.net or 192.168.1.1 in the address field of your browser and then press Enter.
  • Enter admin for the router user name and your password (or the default, password).
  • Choose Wireless Settings from the Menu on the left.
  • Select WPA-PSK under Security Options. Input the Passphrase.
Passphrase can be 8~63 Hexadecimal characters or 8~63 ASCII characters.
Take note of the passphrase then click Apply.
Hope this helps. Have a nice day.
My Atheros AR5007 will only complete a "Local Connection, No Internet Connection" to a NetGear N600 Dual Band Router when Security Options (WPA2-PSK (AES)...ect) are selected on the Wireless...
Since the connection works without the encryption settings, it is NOT a driver issue. It sounds like a missing wireless network security setup problem. So assuming Windows (Mac OSX is similiar):
  1. Connect a laptop/PC to the NetGear via ethernet. It saves on some aggravations later.
  2. Connect to the NetGear and restore the security settings, and remember your keyword.
  3. On your computer, open the list of Wireless Networks (usually Start->Control Panel->Network(ing)->Wireless Networks). The menu sequence might differ slightly, depending on which Windows you're running.
  4. Find and click on "Manage Wireless Networks" (or words to that effect)
  5. Right click on your wireless network's name to get the drop down menu, and select "Properties"
  6. Find a button or tab related to "Security"
  7. Under Security Type, select WPA2-PSK (or Personal)
  8. Under Encryption Type, select "AES"
  9. Under Password (or Security Key), type in your router's WiFi security key word. You may have to log back into the NetGear and find the keyword (yours) or the alternate (gibberish) form.
  10. Save the settings
  11. If you're connected to that wireless network, then disconnect
  12. Try connecting to the wireless network again. It should work this time.
Cant get the ps3 to connect to router with password that i set up...computer does just fine
change the wireless security settings options in router Security Options None
WEP WPA-PSK [TKIP] WPA2-PSK [AES] WPA-PSK [TKIP] + WPA2-PSK [AES]try this link it might help http://manuals.playstation.net/document/en/ps3/current/settings/connectwireless.html
1helpful
How to make a secure connection.So far i have an open connection. My router is Belkin_G_Plus Mimo
Open the router page 192.168.1.1 >> type this in the internet explorer address bar.
1. the Home Page is displayed. Click Wireless from the left menu
8. Changing the Wireless Security Settings
Your Router is equipped with the latest security standard called Wi-Fi Protected Access 2 (WPA2). It also supports the legacy security standard called Wired Equivalent Privacy (WEP). By default, wireless security is disabled. To enable security, you will need to determine which standard you want to use.
To access the security settings, click Security.
The Router features WPA2, which is the second generation of the WPA-based 802.11i standard. It offers a higher level of wireless security by combining advanced network authentication and stronger Advanced Encryption Standard (AES) encryption methods.
2. You can configure wireless security/encrytion settings here. Select WPA-PSK (no server) from Security Mode drop-down menu. The new page will display on next screen
3.Setting WPA Security
Note: To use WPA security, your wireless network cards must be equipped with software that supports WPA. At the time this User Manual was published, a security patch from Microsoft is available for free download. This patch works only with Windows XP.
Your Router supports WPA-PSK (no server). WPA-PSK uses what is known as a pre-shared key as the security key. A pre-shared key is basically a password that is between eight and 39 characters long. It can be a combination of letters, numbers, or characters. Each client uses the same key to access the network. Typically this is the mode that will be used in a home environment.
Setting WPA-PSK
1. From the Security Mode drop-down menu, select WPA-PSK (no server).
2. For Encryption Technique, select TKIP or AES. This setting will have to be identical on the clients that you set up.
3. Enter your pre-shared key. This can be from eight to 39 characters and can be letters, numbers, or symbols. This same key must be used on all of the clients that you set up.
1helpful
Wep
WEP
  1. Connect a computer to any one of the four LAN ports of the Belkin wireless router.
  2. Open your web browser and type the router IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
  3. Click Login on the top of the page to login to the router. By default the Password is left blank, click Submit.
  4. Click Security under Wireless menu
  5. Under Security, Select 64 bit WEP (or 128 bit WEP).
  6. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you.
  7. Apply the settings. Please write down the key – You will need it later to configure your wireless computers with the same key.
Configuring WPA-PSK Encryption:
  4. Click Security under Wireless menu.
  5. Under Security Mode, select WPA/WPA2-personal (PSK)
  6. Select WPA2-PSK as your Authentication
  7. Select AES as the Encryption Technique.
  8. Enter a word or group of characters in the Password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length.
    Note: The PSK (Pre-Shared Key) is case sensitive ("A" is different than "a")
  9. Click Apply changes to save the settings
    DI-524 and VISTA: impossible to configure WPA PSK (AES)
    WPA2 pre-share key must consist between 8 to 63 Ascii characters.
    But you have spaces in the sentence the car is black.
    Space is not a ascii character. Did you try without spaces?
    thecarisblack
    4helpful
    2answers
    How do i password protect my Router???
    follow the steps below:
    5. Under Security, you can select 64 bit WEP (or 128 bit WEP) or WPA/WPA2-personal (PSK). Note: make sure that your wireless computers will be able to support WPA encryption since not all wireless cards/adapters will be able to. if you're not sure, WEP is the encryption to use
    Configuring WEP Encryption:
    1. 1. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you.
    2. 2. Apply the settings. Please write down the key – You will need it later to configure your wireless computers with the same key.
    1. Select WPA2-PSK as your Authentication
    2. Select AES as the Encryption Technique.
    3. Enter a word or group of characters in the Password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length.
    4. Click Apply changes to save the settings.
    once you have enabled your wireless security, you need to reconnect your wireless computer to the wireless signal using your wireless password/network key.
    hope this'll help you and just ask me if you'll have other concern
    ciao!
    2helpful
    Securing wireless network
    I have here the step by step guide from Belkin's Support site.
    9. Click Apply changes to save the settings.
    Top Sony Video Game Consoles & Games Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Jose Ramirez
    Alexander
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
