Since you didn't specify the model of your phone, select it from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
It sounds to me like it is not the fuse if the rear window light is still working.
Instead, check in the trunk of your car. Can you see a wiring loom there? It is usually hidden under the trim. Look for a disconnected or loose plug. If it is not that, then you will need an auto electrician to trace the fault and repair it.
check the bottom by the brake and gas pedals or on the driver side of your dash board and when you find the port fuse on the back of the port it will tell you wich fuse is it all fuses are numberd hope this helps.
