Question about NAD S300 Amplifier
NAD S300 Amplifer humming
I just bought a used NAD S300 Amplifer.When It was power on,it was humming itself.The humming can be heard in 3m.Is the humming normal for the amp? or the amp got something wrong.The amp works order but humming.
Thanks.
Leo
  • NAD Master
  • 5,699 Answers
You have either got a bad earth connection, or possibily there's a capacitor failed.
If you can't find a dodgy conection, I would replace the large Electrolytic Capacitors in the power section, they are used to take out 50hz hum in the mains electric, when they go you get that hum coming into your system.
Posted on Nov 18, 2009
6ya staff
SOURCE:
Amplifier powers up. low humming, and music is barely heard at full volume.
The main amplifer ICs have taken a dump. Time to go shopping!
Nov 15, 2011 | Audio Players & Recorders
Speakers started making a humming noise
HI:
Usually with audio humming, the cause is due to a bad capacitor on the amplifer portion of the unit. Bad filter capactor in the AC power suppy will cause whats known as AC ripple to enter the system causing motorboating sound or humming. Have the unit check by a technician for poor regulated DC voltage.
May 21, 2011 | Altec Lansing VS2421 Main / Stereo Speaker
My NAD S300 stopped working,simply could not start, the blue lamp was blinking constantly. I sent it to an authorized service where they told me that the mainboard is a multilayer structure and due to...
Have someone who has experience working with circuit boards take it apart and look at it. They'll probably be able to tell you what parts can be replaced. If it's anything as simple as capacitors and resistors, then you can find the exact parts you need at AllElectronics.com
When they said it was a multilayer structure, that means either there are multiple circuit boards, or it's all surface-mount soldering on both sides of one board. To be on the safe side, assume it's surface mount. It's much more difficult to work on.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Feb 12, 2011 | NAD S300 Amplifier
I've bought my NAD C326BEE amplifier almost two years ago, and i got promised a hell of a good quality and that it would last for YEARS. But ever since i bought the damn amplifier, it has been shutting off...
I'm also a Nad fan. I find this pretty odd that you should loose two in such a short space of time. The cutting out is due to the "protection circuit". I would be inclined to get your speakers checked out as if they are faulty or not "matched" to the amp, it will trigger the amp to "protect itself" and shut off.
Jan 07, 2011 | NAD C326BEE Amplifier
Nad c270 power amp transfomer hum
if the hum is in the sound output you have a blown power regulator
Mar 31, 2010 | NAD C270 2-Channel Amplifier
Nad 752
i would suspect a missing supply or speaker protect relay shorted? or staying closed too long. I'm not familiar with this model but a common failure is bad connections. Inspect all heat sinked parts and small value resisters used as fuses. Look for cracked solder joints on all parts, tighten pcb grounding screws. Memory is most likely powered by a high value cap or stack cap that maybe bad. Or the diode used to charge during usage maybe leaky , other part in ckt leaky, or the memory device itself is drawing excessive current off the memory cap. I have seen small 0.1uf disk caps turn into 1k resistors.
Nov 05, 2007 | NAD T752 Receiver
Connect turntable to NAD S300
Yes you will need a pre-amp for your turntable, there is no phono input on this amplifier. Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 08, 2007 | NAD S300 Amplifier
NAD S300 Amplifier Logo
633 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
cheekygr1n
Level 1 Expert
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
