KEYLESS ENTRY SYSTEM
You can use the keyless entry keypad to:• lock or unlock the doors without using a key.• open the trunk.• recall memory seat/mirrors/steering column/adjustable pedals positions1 or 2.
The keypad can be operated with the factory set 5-digit entry code; this code is located on the owner's wallet card in the glove box, is marked on the computer module, and is available from your authorized dealer. You can also create your own 5-digit personal entry code. When pressing the controls on the keypad, press the middle of the controls to ensure a good activation. Programming a personal entry code. To create your own personal entry code: 1. Enter the factory set code. 2. Within five seconds press the 1 • 2 on the keypad. Note: The lock motors will cycle, locked then unlocked 3. Enter your personal 5-digit code. Each number must be entered within five seconds of each other. 4. Enter a sixth digit to indicate which personality feature should be recalled by the personal code. Note: The lock motors will cycle, locked then unlocked.
• 1 • 2 recalls driver personality 1.
• 3 • 4 recalls driver personality 2.
• 9 • 0 does not recall a driver personality.
Wait 5 seconds without pressing a keypad button in order to store a personal entry code. Tips:
• Do not set a code that uses five of the same number.
• Do not use five numbers in sequential order.
• The factory set code will work even if you have set your own personal
code.
• If you set a personal code and store it over an existing personal code
it will erase that personal code only.
Erasing personal code
1. Enter the factory set 5-digit code.
2. Press and hold the 1 • 2 for two seconds and release; this must be
done within five seconds of completing step 1.
3. Press and hold the 1 • 2 for two seconds to erase the customer
programmed code; this must be done within five seconds of completing
step 2.
Your personal code is now erased and only the factory set 5-digit code
will work.
personal payments such as depositing a cash from bank on the account of other person or it can be personal payments of 2 persons met to gave the cash personally...
- i read some articles in google that personal payments to and from INDIA was suspended for a few months
