Hotpoint Ultima WDM73 Front Load Washer / Dryer Logo
Posted on Nov 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where Is The Filter ? - Hotpoint Ultima WDM73 Front Load Washer / Dryer
Barry Coates
Level 3:
  • Hotpoint Master 3,463 Answers
  • Posted on Nov 16, 2009
Barry Coates
Hotpoint Master
Level 3:
Answers
3463
Questions
Helped
1406792
Points
12766
Remove lower rear panel.
Remove large black hose on bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for obstruction here and in the pump itself.
Please rate my solution.
Thanks.
Gerry Harvey
Level 3:
Genius:
  • Hotpoint Master 1,482 Answers
Gerry Harvey
Hotpoint Master
Level 3:
Genius:
Answers
1482
Questions
0
Helped
379133
Points
4533
It is withing the sump hose. The hose is connected to the pump. note which way the filter comes out....
1helpful
Display reads clean filter even when the filter is out is there a nother filter inside
You need to reset the filter timer. Press the "options" button, then "3" for filter timer, then "start". The filter timer should now be reset and you shouldn't see it say clean filter anymore. Hope this helps.
1helpful
How do i access the air filter on the PJ551?
Air-Filter
Cleaning the Air Filter
The air filter should be cleaned as described below at intervals of approximately 100 hours. When
the filter is used for approximately 100 hours, the message "CLEAN THE AIR FILTER" appears
when the projector is switched on.
1 Switch the projector power supply OFF, and remove the power cord from the power outlet.
2 Clean the air filter with a vacuum cleaner.
3 Reset the Filter Timer using the function of the FILTER TIME on the OPTION Menu. Please
refer to the description of the "FILTER TIME" on the Table 9: MAIN Menu.
Replacing the Air Filter
Replace the air filter if contamination cannot be removed, or if it is damaged. To order a new air
filter see page 26 for contact information.
1 Switch the projector power OFF, and remove the power cord from the power outlet.
2 Remove the filter cover and the filter.
3 Replace the new air-filter and the filter cover.
4 Reset the Filter Timer using the function of the FILTER TIME on the OPTION Menu. Refer to
the description of the "FILTER TIME" on Table 9: MAIN Menu.
Where is the filter on my rs2630
Removing and replacing a water filter - inside liner location
Filters situated in the interior liner of the refrigerator compartment of Samsung-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Grasp the filter and make a one quarter turn to the left. There should be an indicator line located on the filter bracket cover. The install mark on the filter itself will line up with this indicator line.
  2. Pull down gently on the filter to remove it from the mounting bracket assembly. Be careful to not tip the filter, as water may spill out of it.
  3. Discard the used filter.
  4. Remove the new filter from its packaging, and remove the red plastic cap from filter cartridge.
  5. Apply the appropriate month sticker to the filter to remind yourself to change it again in six months' time.
  6. Line the install mark on the filter up with the indicator line found on the filter bracket cover. Push up on the filter. Turn the filter a quarter turn to the right to lock it in place. The remove mark on the filter should line up with the indicator line of the filter bracket cover.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
What part number for the filter
call your auto parts store, we don't know if it's the air filter, fuel filter, oil filter, cabin filter, pvc system filter, transmission filter, p/s filter, don't know what kind of car, size of engine, need to know more information that I NEED A FILTER.
1helpful
How much oil should i put in at an oil change on a 2001 monte carlo 3.4
Hello, this is the oil capacity of your vehicle.
I hope this info is helpfull
  • with filter change
4.1 liters
4.3 quarts
  • without filter change
3.75 liters
4.0 quarts
  • 3.4L (LA1)
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
  • 3.4L (LA1)
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
  • 3.4L (LA1)
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
  • 3.4L (LA1)
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
with filter 4.3 quarts
without oil filter 4 quarts
Where is cabin air filter location
Hi if you have the 3.8 then follow these instructions.
Hi
  1. Left sound insulator panel.
  2. HVAC air filter access cover.
  3. Pull first filter out using filter tab. Filters will bend to clear accelerator pedal.
  4. Pull the second filter out using tab.
  5. Pull the third filter out using tab.
Install or Connect
Important
  • When installing the filter care should be taken so that the filter does not become dislodged from the channel inside of the HVAC module.
  1. First filter in case. Use the tab and raise the filter parallel, so that the leading edge catches on the holding rib.
    • A long thin bladed screw driver may be useful in lifting the filter parallel to the HVAC module.
  1. Engage the second filter in the tab of the first filter and slide it into the remaining channels of the first filter.
  2. Use the tab and raise the filter parallel, so that the leading edge catches on the holding rib.
  3. Engage the third filter in the tab of the first filter and slide it into the remaining channels of the second filter.
  4. Fold the second filter tab down and the third filter tab up and over the second.
  5. HVAC air filter cover.
  6. Left sound insulator
2answers
Shop manual for 2005 Santa Fe 3.5L shows a fuel pump filter in the tank & a standard cylindrical fuel filter outside the tank. Manual states change the "fuel filter" at 45000 mi. Can't find outside...
Change to Exterior filter not the tank filter. The in tank filter is actually a sock located on the Fuel Pump in the tank. This is rarely a problem. The exterior filter is going to be in-line most likely on the passenger side of the vehicle toward the rear. Easiest way to locate it is to trace the fuel lines back tot eh front of the vehicle from the fuel tank.
1helpful
2answers
How to change cabin air filter?
Place the ignition switch in the Off position, remove the supplemental inflatable restraint fuse from the rear fuse panel. On 1997 models, the rear fuse panel is located in the luggage compartment. On the 1998-2003 models, the rear fuse panel is located under the rear seat. Remove the two retaining screws from the rear edge of the left sound
insulator. Push in on the snap tabs to release the insulator. Disconnect the left sound insulator electrical connectors, then remove the insulator. Twist the shift cable grommet and position away from the cabin air filter access door. It may be necessary to cut the tie strap and peel back the foam insulation to position the grommet away from the door. Remove the cabin air filter access cover from the A/C and heater module.
Remove the tape, then pull out the first cabin air filter element using the filter tab. Remove the tape, then pull out the second cabin air filter element using the filter tab. Remove the tape, then pull out the third cabin air filter element using the filter tab.
To ease installation, lubricate the new filter guides with silicon spray. Install the first clean air filter into the case. Using a long thin blade screw driver and filter tab, raise the filter until it is parallel with the A/C and heater module. Ensure the leading edge of the filter engages the filter case holding rib. Engage the new second cabin air filter in the tab of the first filter. Slide the second filter into the remaining channels of the first filter. Using the filter tab, raise the filter until it is parallel
with the A/C and heater module. Ensure the leading edge of the filter engages the filter case holding rib. Engage the third new cabin air filter in the tab of the second filter. Slide the third filter into the remaining channels of the second filter. Fold the tab of the second filter down. Fold the tab of the third filter up and over the second filter.
Install the A/C and heater module filter cover. Ensure the cover is properly seated. position the shift cable grommet. Position the left sound insulator to the instrument panel, then connect the electrical connectors. Install the left sound insulator fasteners. Torque the fasteners to 18 inch lbs. Be sure to install the fasteners in the proper locations, then install the SIR fuse. From a position off to the side of the air bag module, place the ignition switch in the "On" position. The air bag warning lamp should flash 7 times and then turn Off. Place the ignition switch in the "Off" position.
3helpful
3answers
Tranny Filter
A lot of auto parts come in the form of a filter which is designed to remove impurities and foreign objects from a stream of gas or liquid. A typical car employs an oil filter, a transmission filter, a fuel filter, and an air filter. However, there is yet another type of filter which is least common to car owners. The cabin air filter, also referred to as the passenger compartment filter, the pollen filter, the dust filter, or the interior ventilation filter is inherent in vehicles manufactured in the 80�s. More and more vehicles are now equipped with cabin air filters, but what exactly is a cabin air filter? The cabin air filter is tasked to eliminate almost all of the airborne elements that come with the air that enters the passenger compartment. It is guaranteed to enhance the quality of the air that goes around the passenger�s area. The cabin air filter is attached under the dashboard, behind the glove compartment or in the engine chamber. Your factory cabin air filter may be worn and torn with use and time, which is why an aftermarket Chevymag-glass_10x10.gif cabin air filter replacement is manufactured. The Chevy cabin air filter replacement is designed to ideally replace your factory cabin air filter which is created to top the performance of your old one. The Chevy cabin air filter replacement is ideal to use because it helps purify the air and remove particles that might cause the passengers allergic reactions. It is highly beneficial not only to the car occupants, but also of the car driver so that he will not get distracted from controlling the maneuvers of the vehicle operation.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
