Ricoh Aficio CL3500N Laser Printer Logo
Posted on Nov 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sc491 error on ricoh MPC 3500
I am receiving an sc491 error on my /ricoh MPC 3500.
  • Anonymous Mar 25, 2014
    redial settings
deni natanael
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 08, 2015
deni natanael
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
8378
Points
5
Replace drum black and swing to drum yellow....
Anonymous
Level 2:
Sniper:
  • Expert 58 Answers
  • Posted on Feb 26, 2010
Anonymous
Expert
Level 2:
Sniper:
Answers
58
Questions
0
Helped
64026
Points
131
Sc 491 straight from manual
High voltage power: Drum/ development bias output error
An error signal is detected for 0.2 seconds when charging the drum or
development.
 High voltage leak
 Broken harness
 Defective drum unit or development unit
 Defective high voltage supply unit
1. Check or replace the harness.
2. Replace the drum unit or paper transfer unit.
3. Replace the high voltage supply unit.
Ricoh Aficio Mp C2050 error code sc491 what is the poblem
An error signal is detected for 0.2 seconds when charging the drum or development.
• High voltage leak
• Broken harness
• Defective drum unit or development unit
• Defective HVPS-CB board
2answers
Printer Ricoh sp 210 su in error service call sc556
This is most likely a fuser issue. If you have a spare laying around, I would suggest replacing your fuser. If you have a contract with Ricoh, I would suggest placing a service call for them to come out and look at the machine.
2answers
Service call-sc491
Possible fixes from previous FIXYA question.
Use Comment menu to add information.
For example, what model Ricoh printer is it?
Have you replaced toner recently? If so, was it Ricoh original or not?
http://www.fixya.com/support/t26593905-printer_ricoh_sp_210su_service_call
Printer Ricoh sp 210SU service call error SC491 using compatable cartridge...
Plz help sc 681 in ricoh mpc 4500
• NoiseRFID: Communication error • Communication error occurs when the RFID starts to communicate with the RFID receptor. • Retry of RFID communication fails three times after the machine has detected the RFID communication error.
The problem is Defective RFID reader and writer • Disconnected ASAP I/F • No memory chip on the toner cartridge • Noise
Erorr problem code sc 336
No such error code. There is a 363. That is for a bad yellow developer unit.
3helpful
2answers
1helpful
Ricoh Aficio SP C420dn Printer. The printer at
sc491 is a high voltage output error. Combined with your jamming issue, it sounds like a possible electrical problem somewhere. A good first step is to turn the machine off and unplug it, then take off the covers and reset any connections or cables you can get to.
If the problem persists, you should have a service technician take a look at it because it might need a board replaced.
Ricoh rex rotary sc 548
Hello wajidsn
SC548 : "Fusing Installation Error.Fusing Unit Set Error"
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
