Hi, I am a winding expert and I am running my own repair shop since 10 years.Recently I came across repairing of Demolition Hammer Drill:GSH-11E.The armature winding was burnt and when I tried to rectify the same,the whole armature was burnt after running for a while. May I get a assitance to do the proper winding and the technical details of it ? I could see that the winding was fractional pitch and it is a 12 slot/2 pole.But could not go beyond it.Any help in this regard will solve my problem.
Thank you
Sidharth
India
SOURCE: Bosch demolition hammer oozing grease/oil.
Look around there for some O rings we have had this same problem with some of our Bosch hammer drills, and they usually replace a set of seals around the nose of the tool
SOURCE: i need an schematic diagram for repair a kango
they went out of business a few years ago,i have some parts no manual i need one also
SOURCE: bosch demolition hammer bearings are ceased up, how can I remove it properly to replace?
Ok here goes. Purchase or use the bearing cover nut 3613461500 that you have taken from the base of the machine. and drill a 6mm hole in it. remove the armature from the machine and measure how far the end of the armature sticks out of the bearing. then fit the cover nut onto the bearing holder and whilst supporting the cover nut use a puller or press to press the armature off the bearing through the cover nut. Replace the bearing in the holder and press the bearing and holder back onto the armature until the amount of armature shaft showing is to the same distance that measured in the first place. Hope this helps.
