I lost the charger for the 18v PSO1800 Type cordless drill
I lost the charger for the Black and Decker 18v PSO1800 Type 3 cordless drill. I found several 18V DC chargers, but I need to know What the amperage rating for this model is. Any help would be appreciated.
it is probably the brushes on the motors are wore out or stuck and not making contact. pretty much junk unless you feel confident enough to attempt repair.
Generally, When your have the 18V milwaukee drill, you had better to use the same voltage battery charger to charge the battery. it will be more safe. John. http://www.anybatteries.com.au/battery-model.php/Power-Tools-Battery_milwaukee.html
Either the charging adapter is faulty or the battery is worn out.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
u can call black&decker and get one that way or go to your local hardware store or the place you bought it from and you should be able to get another one.
Check Home-Depot. I bought my charger there
for about $ 30.-. There is also a cute Combination of AM/FM Radio/Charger on the
Market, specifically for 18V Batterypacks.
I don't know if I would try this or not. there could be a difference in the amps and usually a charger is designed to shut off or go to trickle when the battery is fully charged.
