Question about Yamaha Music
Our Yamaha clavinova CLP-115 is buzzing, even with
Our Yamaha clavinova CLP-115 digital piano is buzzing, even with the power cord unplugged. Any ideas?
  • Yamaha Master
  • 5,603 Answers
Without power to the unit no sound should be generated. Make sure there are no other connections.
MAYBE you have a wall transformer behind it that is buzzing. MANY wall transformers develop buzz.
Another source is flourescent lights and even some of the low voltage halogens have noisy transformers in the base.
Posted on Nov 18, 2009
6ya staff
SOURCE:
Yamaha Clavinova Piano CLP-122S pedals connector
This should help you trace the wires
May 05, 2018 | Yamaha Music
Does a Yamaha clavinova clp 760 have a fuse that may need changing
There are a number of fuses on the main power board ( by transformer ) the sizes differ depending on the country of use but are clearly marked on the board.
REMEMBER TO UNPLUG FROM THE MAINS BEFORE OPENING - if in doubt seek the advice of a qualified electrician
Mar 07, 2015 | Yamaha Music
HOW TO REPLACE CONTACT STRIP OF YAMAHA CLAVINOVA CVP 92 DIGITAL PIANO ?
Successful repair of my Yamaha Clavinova CLP 880
The principal to replace your contact strip will require one further step to that shown here where the customer has replaced the felts.
When you have the keybed out you will see the contact strip part 220. This is held in place behind the circuit boards. Remove boards, replace strip and reassemble.
It might be worth considering felts whilst you have the keyboard in bits as these wear out.
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=19108
Aug 09, 2014 | Yamaha Music
Yamaha clavinova cvp55
Try resetting the piano.
Mar 05, 2014 | Music
Yamaha Clavinova CLP-440
It sounds like you have a part overheating and failing, then cooling off and starting again. i would take it into the nearest Yamaha repair facility or contact your local authorized repair to come take a look before it goes out of warranty.
Mar 07, 2017 | Music
I know that a Clavinova cannot get out of tune, but - in the lowest two octaves - my mom's CLP-115 sounds as if it is. Might this be a problem with memory, speakers or circuitry? Any idea how we might fix...
Realize that it MAY be stretch tuned like a real piano. A real piano is tuned increasingly sharp above middle C and increasingly flat below middle C. At the ends, the the off tuning is about 20 to 22 cents sharp and flat. The Clavinova should emulate this. In a real piano this makes it sound better and prevents some cross coupling of harmonics. Read up about stretch tuning on the internet. The Clavinova gets its reference from a quartz crytal oscillator and they just dont' get out of tune.
Mar 28, 2011 | Music
I have a Yamaha Clavinova CLP-50 Digital Electric Piano serial number 19071 and would like to find its age. Many thanks Phil
If you will turn the instrument upside down you will find a date of production somewhere. My CLP-50 has been built in 1985 for example, I discovered in 2006. (I have forgotten the exact location of this date.)
Jan 03, 2010 | Yamaha Music
Yamaha clavinova clp 200 - ear phone jack slid
The control panel hinges upwards and you have to move the keybed back a bit to get at the jack. All the screws on the bottom for the keybed. I'm not sure where the ones for the control panel are.
Oct 12, 2009 | Yamaha Music
Yamaha Clavinova CLP 260
hi...
Your L/R jacks in the back need to connect to the "line-in" connector on your sound card.
I think the jacks on the Clav are 1/4 inch. Go to Radio shack and ask for an adapter that will take two 1/4 inch plugs/cable and convert it to a 1/8 inch stereo plug.
The Midi connects From (keyboard) To (soundcard)
Cables are available at any music store
Jan 12, 2009 | Yamaha Full-Size Keyboard
Yamaha clavinova won't play C natural in any octave
Hi ...
There are flexible cables that connect the keys to the main electronics. The connectors for those cables sometimes age poorly..
It is fixable. But dont "get taken" on a repair.
If it's just resoldering a few points,it shouldnt be more than $100.00
to fix
Jan 04, 2009 | Yamaha Full-Size Keyboard
Music Logo
814 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
