How do I dismantle the oven door, so I can clean the spilled streak marks on the inner side of the glass door
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
We are attempting to replace the broken glass in the oven door. door has been complety disassembled and we need assembling instructions.
I need info as soon as possible.
Thank you
Wanda Lawton
330-467-5551
HOW TO REPLACE DOOR HINGES ON KITCHENAID WHIRLPOOL OVEN You will have to disassemble door on pieces to clean all glass.
This repair is for a Jenn-air electric range (Jenn-Air JER8785QA-Maytag JER8785QA) that has streaking in between the interior glass panes. This oven has three glass panes. The outside pane is removed by removing the top three screws on the door and two on the bottom. Loosen the third bottom screw slowly as the front glass panel will come out fast. The interior double pane glass is removed by removing the six screws inside, and then take off the front of the door including the handle as a single unit. Be careful as the double glass pane unit is just resting on the brackets and will fall out. The interior double pane can now be removed and disassembled. The metal holding the two glass panels just has a metal tab that can be bent straight to remove the glass panels for cleaning. Put the glass back in and reinstall any fiber glass that came out with the panel. It is much easier with two people.
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
I have a similar problem
Same problem. How can we clean the inner glass
I have the same problem with my Maytag Precision Touch Control 500.
OVEN IS STAINED INSIDE GLASS
How do I remove the oven door on Kitchenaid model KEMS377DAL1. The inter door glass is broken
can not remove door to clean oven
i need to replace the glass in the oven door
The door to the top oven in my Maytag Gemini double oven has streak marks inside the glass door. They drive me crazy! How can I get rid of them (easily)?
As above
The glass has stains or markings in between the sealed glass
Glass door rattles
