Question about LG Flatron 575MS 15.1" LCD Monitor
I've lost my power cable...where can i purchase a replacement one for my LG flatron 575ms
    New Friend:
  • 65 Answers
Here's a link for one on ebay: http://cgi.ebay.com/Power-Adapter%3a-LG-Flatron-575MS-LCD-Monitor-(12V-4A)_W0QQitemZ370109233697QQcmdZViewItem?rvr_id=&itemid=370109233697
you can also google the following: LG flatron 575ms power cable
there should be several listings
Posted on Nov 18, 2009
6ya staff
SOURCE:
Lg flatron w2240
You might need to change the monitor's power supply. I have seen similar problems with other LG models. Usually it is easier to replace the power supply than trying to troubleshoot it.
Replacing the power supply usually involves a few screws and a few cable connections. Troubleshooting the power supply board itself usually involves soldering replacements for blown capacitors.
Oct 26, 2013 | Computers & Internet
My monitor flickering when I touch or tight the monitors VGA cable then display will come what is the problem of the monitor
I think your cable is damaged.
I've you can pull your VGA cable (BLUE) out of your monitor, you can replace it by a new one.
I've not, you need to get it fixed.
Please rate my solution.
Thank you for using FixYa.
Jun 24, 2011 | LG Flatron L1715S 17" LCD Monitor
Lg logo appears then goes in to power saving mode LG Flatron Wide Monitor
Hello davidhague99 ,
Check your VGA cable if connected properly to your CPU or Video Accelerator Card,if connected properly,try another VGA cable and if the problem persist you need to try another source.
hope it helps thanks
Jun 11, 2011 | LG FLATRON L1919S-SF 19 inch LCD Monitor
LG Flatron 575MS 15.1" LCD Monitor Need 24 volt power supply
alkarim 15, Are you looking for an "open frame" switcher or a "open frame" linear dc supply. Does it need to have regulated output or if linear type just brute force output.What is the current requirement of the circuit you will use with the power supply? Have you checked www.jameco.com or www.digikey.com or www.newark.com . Does it need to be AC or DC output? 12fixlouie
Aug 27, 2010 | LG Flatron 575MS 15.1" LCD Monitor
I have a L194WT LG Flatron monitor. One day it
Same problem started happening two days ago and ever since. I called LG and the product falls under a 3yr product warranty according to them (from my original purchase date of January 20, 2007). They will send packing slips to me so I can send the defective unit back to LG. I was told I am eligible for a replacement monitor - which will be shipped to me within 10 to 14 days (consecutive days, not business) - although I'm not sure what I'm being sent in return. My suspicion is that this monitor issue is a known issue by LG and they are quietly replacing the unit to those who follow through by calling CS.
Tips: Have your original purchase date on hand (in the form of a receipt) just in case they want proof of purchase.
Apr 16, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Jan 26, 2008 | LG Flatron L1511S 15" Flat Panel LCD...
Foggy screen
get some fogoff at your local hardware store
Dec 14, 2007 | LG Flatron L1750S 17" LCD Monitor
LG Flatron 575MS 15.1" LCD Monitor Logo
384 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
