I HAVE AN ERROR SC 322 WHEN i GO TO PRINT
Error Code SC322:
1st laser synchronization error
The 1st laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Possible Causes:
+ Poor I/F harness connection between the laser synchronization detector board and the LD unit.
+ Laser synchronization detector board out of position and angle of reflection not correct
+ Laser synchronization detector board defective LD unit defective
Not sure what your expertise is on this, but unless you know how to service the machine yourself, this one is going to require a service call...
There have been instances where toner drops onto the LD Unit and creates problems like this. About a month ago I replaced the Laser Synch. Detector Board in a 1045 for this exact problem and error code.
I'd start by cleaning up any toner on the LD unit, and re-seating all the electrical connectors on the laser unit. If that doesn't clear things up, it's probably one of two things, the LD Unit or the Synch. Board. I'd lean more towards the Synch. Board myself, but you never know...
Sy punya mensi gestetner MP 2501L, muncul code error SC322, gimana cara mengatasinya
SOURCE: ricoh 1035 laser problem
sometimes
the plastic of the laser is turned by the heat proves to relax and to fit the
screw that holds the laser unit that is of the side of the drum while it raises
a millimeter with a screwdriver, this sometimes works.
Verifies that the glasses and mirrors well
be positioned correctly.
Other
Poor connection between the laser
the LD unit.
out of position
defective
LD unit defective
