First you need to determine if it is optical skew or mechanical skew.
If the machine is used as a printer then do the computer prints come out skewed? If it is not connected to a PC then print out the counter list using UserTools/Counter. If that prints straight then you are dealing with optical skew. Ricoh's in general are bad about the left front corner of the machine drooping from someone pushing down on that corner. If you have optical skew try lifting up the left front corner of the copier and try making a copy. That might fix your problem.
If the UserTools/Couter print out is skewed then your back to a mechanical skew and there are numerous causes for that.
The optical skew is more likely so let's start there.
Testimonial: "Thanks for the input. I will try these tips and get back to you. Thanks again."
Belt Edge Learn - to align the Transfer Belt positioning system.
Fine Skew Setup - automatically performs horizontal and vertical alignment, and reports any skew in the various images caused by ROS misalignment. This skew must be corrected through manual adjustment
IN/OUT Setup - automatically performs magnification adjustment so that scan lines are the same length for all four colors. Also checks for skew.
Center Setup - Aligns the midpoints of scan lines for all colors, for magnification balance
