Whirlpool Inglis IP4400 Washer Logo
Posted on Nov 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washing machine will not enter spin cycle. When turned to spin there is a humming noise but no movement. Checked drain lines and they are not plugged.
Anonymous
Level 2:
Sergeant:
  • Expert 289 Answers
  • Posted on Nov 18, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
289
Questions
Helped
63820
Points
614
The washer goes in one direction for wash and the other way for spin.sound's like you have a bad motor.
Washer (total care system) is making a humming noise even though I've taken all the clothes out of it. The agitator works, but there's a humming noise. I've stopped it and re-started it, but...
Hi
1 of 2 things could be the trouble.
Does the washer drain properly if you manually turn the control knob? If not then this sounds like your pump is either plugged with possible lint and can't move or has died completely. 99% chance pump is the problem and 99% chance it can be an easy fix by cleaning the pump where the Drain Line is attached, worst case scenario pump is to be replaced, but not a overall expensive fix and most can do it without a technician.
Second problem is possibly the time itself, but if the washer is going through all cycles except spin then pump is likely the culprit, cause in spin cycle the machine has to drain the water from the unit as it spins, if it cannot the washing machine basically stops and cannot complete the cycle.
One way to tell for sure if the pump is the problem. When the machine enters the spin cycle and starts making that noise. Manually turn the dial a little bit till it passes the spin cycle, if it continues to wash till it hits the final spin/drain cycle then stops again...your pump is in need of help.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Washing machine does not spin on spin cycle,only hear a humming noise.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Have a Fisher & Paykel GW712 washing machine. Initially - with the power on at the wall and not turned on at the machine - there is a hum coming from the machine. The washer did not work (agitator...
Hi just read your posting.Now when you hear the humming noise, even though the machine is not powered up, is the noise comming from the top near the MOTOR CONTROLLER? Why did you replace the RPS ?If the hum is coming from the CONTROLLER then your CONTROLLER might be faulty.When the machine is not powered up no noise should come from it at all.Please reply with additional information on the questions and I am sure I can help you rectify this fault.
The wash cycle clicks on and a small amount of water enters the drum, as normal, but then there is just a humming noise and the drum does not move. When I put it on the rinse and spin cycle (there is...
I removed the bottom panel under the door and drained the the tub. There is a white filter housing that unscrews, but you need to have towels handy to catch the water that comes out. The machine appeared to work after that but it would'nt drain and it turns out that the humming noise was coming from the drain pump connected to the filter. I ordered a new drain pump assembly, which should be easy to replace since it is located at the front of the washing machine.
Washing machine making whining noise during spin only
Its a bearing on its way out. the seal is also probably worn.
1helpful
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
2helpful
GE washing machine does not run, gives humming noise
A washing machine is a simple product.
When trouble shooting anything you have to know what is supposed to do and what is it not doing.
At the begining of a washing machine cycle the machine fills with water until a switch is made telling the machine it is full and ready to agitate. Since it never fills it will stick in that part of the cycle.
When you start a cycle and no water enters the drum you have one of three problems:
1. The water supply is shut off.
2. The solenoid valve that supplies the water is not opening.
3. No power to the washing machine.
Since you are hearing a hum, the machine seems to be trying to activate that valve,
The humming noise comes from the electromagnetic field that activates the valve,
5helpful
2answers
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
