Obd2 system rediness status won't clear so I can run the smog test due to replacing the battery.
takes a long time to run the rediness test since there are 6 different tests to complete...
PROCEDURE 1
EVAPORATIVE EMISSION SYSTEM LEAK MONITOR
Inspection Conditions
Engine coolant temperature: 30°C (75°F) or less (The engine is stopped before the test drive is started).
Atmospheric temperature: 5 - 30°C (41 - 113°F).
Condition of A/T: Selector lever D range.
Fuel remained in fuel tank: 30 - 50% is recommended.
Time required: 16 minutes or less after started the engine.
Drive cycle pattern: One trip monitor (from start to ignition switch to "LOCK" (OFF) position. Well be completed while traveling with the following drive cycle pattern.
Test Procedure
Engine: start.
Accelerate until the vehicle speed is 89 km/h (55 mph) or more.
While keeping the accelerator pedal opening degree constant, keep the vehicle speed at 89 km/h (55 mph) or more and travel for 16 minutes.
Return the vehicle to the shop, then turn the ignition switch to "LOCK" (OFF) position.
PROCEDURE 2
FUEL TRIM MONITOR
Drive Cycle Pattern
Engine coolant temperature: 100°C (212°F) or less.
Atmospheric temperature: -10 - 60°C (14 - 140°F).
Time required: 30 minutes or more.
Drive cycle pattern: One trip monitor (from start to ignition switch to "LOCK" (OFF) position). Will be completed while traveling with the following drive cycle pattern.
Test Procedure
Engine: start.
While keeping the accelerator pedal opening degree constant, keep the vehicle speed at 89 km/h (55 mph) or more and travel for 30 minutes.
PROCEDURE 3
CATALYTIC CONVERTER MONITOR
Drive Cycle Pattern
Atmospheric temperature: -10°C (14°F) or more.
Engine coolant temperature: Not set.
Time required: 16 minutes or more.
Test Procedure
Engine: start.
Travel for 300 seconds or more while keeping the vehicle speed at 89 km/h (55 mph) or more.
Decelerate until the vehicle speed is within 80 km/h (50 mph) or less.
While traveling at 56 - 80 km/h (35 - 50 mph) for 10 minutes or more, fully close the throttle at least once in 2 minutes and decelerate for 10 seconds or more.
Do not repeat deceleration too often.
Vehicle speed may go below 56 km/h (35 mph) after the deceleration.
Stopping and braking are permitted. (If stopped or drive at 56 km/h (35 mph) or less for more than 5 minutes the monitoring may be stopped. In this case please restart monitoring from the beginning.)
After completing the above deceleration, bring the vehicle speed back to 56 - 80 km/h (35 - 50 mph) and keep it in the range until starting the deceleration again.
Repeat the above deceleration at least 5 times.
PROCEDURE 4
HEATED OXYGEN SENSOR MONITOR
Drive Cycle Pattern
Engine coolant temperature: 100°C (212°F) or more.
Atmospheric temperature: -10°C - 60°C (14 - 140°F) or more.
Test Procedure
Engine: start.
Accelerate until the vehicle speed is 56 - 80 km/h (35 - 50 mph).
While keeping the accelerator pedal opening degree constant, keep the vehicle speed at 56 - 80 km/h (35 - 50 mph) and travel for 16 minutes or more.
Stopping and braking during this operation are permitted. Keep the accelerator opening degree constant for 1 minute or more after each acceleration.
PROCEDURE 5
EXHAUST GAS RECIRCULATION (EGR) SYSTEM MONITOR
Drive Cycle Pattern
Atmospheric temperature: 5 - 60°C (41 - 140°F).
A/C switch: OFF.
Test Procedure
Engine: start.
While traveling 16 minutes or more at 56 - 80 km/h (35 - 50 mph) with engine speed 2,000 r/min or above, fully close the throttle at decelerate for 5 seconds or more until the engine speed reaches 1,000 r/min or under.
Stopping and braking are permitted (Rapid deceleration and sharp steering are not permitted).
After completing the deceleration, bring the vehicle speed back to 56 - 80 km/h (35 - 50 mph) and keep it in the range until starting the deceleration again.
Repeat the above deceleration at least 8 times by fully closing the throttle valve.
PROCEDURE 6
OTHER MONITOR (Main Components, Sensors & Switches, Wire Breakage & Short Circuit)
Drive Cycle Pattern
100°C (212°F) or less (Except engine coolant temperature sensor monitoring).
30°C (86°F) or less (Engine coolant temperature sensor monitoring).
5°C (41°F) or more (Except engine coolant temperature sensor monitoring).
-10°C (14°F) or less (Engine coolant temperature sensor monitoring).
Time required: 21 minutes or more.
Test Procedure
Engine: start
Accelerate until the vehicle speed is 56 km/h (35 mph) or more.
While keeping the accelerator pedal opening degree constant, keep the vehicle speed at 56 km/h (35 mph) or more and travel for 16 minutes or more.
Return the vehicle to the shop.
After stopping the vehicle, continue idling for 5 minutes, and then turn the ignition switch to the "LOCK" (OFF) position. Moreover, the vehicle should be set to the following conditions for idling.
A/C switch: OFF
Lights and all accessories: OFF
Transmission: Neutral
if it was the sensor why would it keep re-igniting and shutting off repeatedly, it seems like board is acting independently of the sensor.
Thanks alot, I will see if that takes care of it.
