This is an ice maker in a top mount firgidiare.Ice maker was installed the water line has no kinks in it.
When you put the arm in the down position nothing happens. It doesn't call for water. Have any suggestion as to what is wrong.
After 24 hours the ice maker started calling for water and has worked every day since then. There is a temperatur seeting programed in the ice maker. When the freezer reaches a certain temp. then the ice maker will call for water and only then will it call for water. The freezer must be cold enough to make the ice machin call for water.
Thanks for trying to help, but this was the problem and I found the solution.
123Lee
I have the same problem. I've had the freezer for 2 years & ice maker just stopped making ice this week. Freezer works O.K.
Hello friend, thanks for your post!
Depending on which style Frigidaire refrigerator you have it is different priming each water line. For a top mount refrigerator you would need to install the icemaker and turn it on with the wire arm. The first cubes of ice for 24 hours should be discarded. On a side by side refrigerator and a french door bottom mount you would need to push on the water dispenser for two to four minutes releasing the water into a glass. I hope this information is helpful.
ice
