Question about Cameras
LCD LEN IS DAMAGED
WHEN I TAKE A PCTURE LINES ARE ACROSS ITIN THE LCD LENS A ND I CAN'T TAKE ANY PICTURES IN THE DAY-LIGHT
  • 346 Answers
HI,
The best thing to do is to take it in and have someone look at it. LCD screens can be tricky to repair. If I had the brand of camera it was I could get you a website to go to for repair help. Sorry I couldn't give you better news.
Posted on Nov 19, 2009
    New Friend:
  • 28 Answers
Your LCD is not crashed,right? if yes, your Lens is broken maybe. You could go to repair center to confirm it.
If needed, you could replace a new lens by yourself. we are supplier for camera supplier including LCDs and Lens, You could email us at judy@think-tec.com or szaideal@hotmail.com hope we can help you to relive your camera.
Posted on Nov 20, 2009
6ya staff
SOURCE:
When i take a photo ,the image has horizontal line across it ...? what's should i do .is it lens problem ?
The fact that it takes the pictures ok confirms that it's not the ccd which has failed. A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs. This, isn't a good new, but hope helps to solve it.
Samsung themselves wouldn't normally bother; a warranty claim usually means they chuck your camera away and send you a replacement. If you're in the UK click here for details of how to proceed with Samsung.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day
Dec 19, 2011 | Samsung S860 Digital Camera
Lines across the picture on screen after picture taken.
CCD (Charge Coupled Device): one of the two main types of image sensors used in digital cameras.
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card. A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image).
If seen on both your pc monitor as well as the camera's LCD then it's likely a CCD issue and it's no wonder that it will be more expensive than buying a new digicam. This is why you need to be exceptionally careful when taking care of your camera since most are uber sensitive to being damaged by the slightest miss-handling.
Hope helps.
May 29, 2011 | Sony Cyber-shot DSC-S600 Digital Camera
There are gray fuzzy lines across the pictures
Sounds like it could be cracked glass or a dirty lens. if its a cracked lens take it to a repair shop or buy new. if its a dirty lens whew! you saved some money just clean it off good luck please rate,
Rshutterbug
Aug 17, 2009 | Canon PowerShot A75 Digital Camera
Kodak Easyshare M753 Camera LCD vertical purple lines bad focus
There is no hope for the display..Plan on spending about 50 - 70 dollars for a new TFT display.
Nov 23, 2008 | Kodak Easyshare M753 Digital Camera
Dropped my nikon coolpix camera and now when i take pictures there are lines across the picture.
LCD screen is damaged. please contact nikon for possible warranty repair.
http://www.nikonusa.com/Service-And-Support/Service-And-Repair.page
Contact Nikon Product RepairEmail Nikon Service and Repair
1 800 645 6678
24 hours a day 7 days a week
Contact Nikon Parts DepartmentPhone: 1 310 414 8107
Fax: 1 310 322 6979
7am – 3pm PST Mon – Fri
Nov 01, 2008 | Cameras
Lines across the LCD screen
Two things can cause lines across the LCD either horizontal or vertically. The first (and most likely) is a small crack in the display wafer. LCD stands for Liquid Cristal Display. They are very fragile and can be easily damaged if dropped. I broke one in my pants pocket.
The second would be if a pin on the ribbon cable (to the LDC wafer) was not making good contact. If you disassemble the camera it is possible to clean the contacts using contact cleaner (or alcohol). Only attempt this is you are willing to replace the camera if you don’t put it back together properly.
Mar 11, 2008 | Sony Cyber-Shot DSC-P100 Digital Camera
LCD screen shows weird colours
Gimbo again. Think LCD damaged will need to repair. Pics. as normal when viewed or printed.
Why has nobody commented?
How much to replace screen? Any ideas?
Feb 16, 2008 | Cameras
Lines appear
normally that problem occurs when the obturator is allways opened, to be fixed needs to exchange the lens
Jan 22, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Cameras Logo
13 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
