SOURCE: Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out Wikipedia.org for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Panasonic/Panasonic_Lumix_DMC-TZ3
The link refers to Panasonic's tests on Panasonic cards. Hardly surprising that all of them are compatible!.
Why would any SDHC card NOT be compatible with the camera if the card itself is not dodgy?
The manual specifies SDHC cards MUST be used for 4Gb and larger. For 2Gb and les, SD are OK.
My problem is that the 4Gb SDHC card works OK in the computer (and therefore is seemingly OK), but doesn't work in the camera. That is what I can't understand.
SOURCE: I put a 4GB Sandisk SDHC card into my Panasonic
no way to solve...only SD is applicable...4G SDHC is not suitable for it
SOURCE: Sammi James - number 1 spammer expert on FIXYA
Iam sorrie but try a other sd card and it will work..
SOURCE: SD card - memeory card parameter error
The manual for the camera states that the memory card must be formatted in the camera and that cards formatted in a computer may not work properly. Use the format command in the camera.
