We recently updated the Firmware from the 0150 error code, it worked fine for a couple of days and now is presenting this error code? Does anyone have a clue as to what it is?
I had the same problem. Pull the Fuser and check Conector.Sometime pieces of paper inside the Conector raises an error.
Please Rate .
6030 error indicates thermistor or heat lamp in fuser or thermal cutout is open circuit, replace fuser assembly is the fix.
Parsonsr note: 4 codes start with F and the rest are all numbers like 6030 or 0150
I really need help on my copier give error E32
Hi ,
Kyocera prointers error codes should start with a letter ie A-G. Can you post this error code adn i can tell you whats up with it.
Cheers,
R
Thanks, we replaced the fuser assembly and it appears to have resolved the problem. Thanks for the assitance and advice, couldn't find the code on Kyoceria's site to save my life.
