Region codes is a built-in feature of the DVD system designed to
control where discs are viewed and distributed. All DVD hardware and
software is coded using one of six numbers ( DVDs Regions 0 , 7 and 8
are special cases - see below ). The U.S. and Canada use Region 1.
Region 2 discs are used in the U.K. , Europe and Japan . While
Australia and the Caribbean use Region 4. These codes determine where
the discs can be played.
Your console must match the discs region code.
This is not the case so you wont be able to play with this game.
Hope it helped.
The disc you are playing is from a different region then your console. Did you purchase the game in a different country then you bought your xbox?
The wrong region error on your DVD or Blu-ray player means you are trying to play a disc that is not meant to be played in your country.
The simplest solution to get around the region code issue is to rip the Blu-ray/DVD disc you want to play to MP4 so that you can play it on your Xbox. Check out how to rip and convert Blu-ray/DVD to MP4 in this article: How to Rip and Convert Blu ray to MP4 with Blu ray to MP4 Converter
What is NANO options
SOURCE: psp region coding
To change your region code you need to go to NANO options, then ID Storage tools, then Change region. It will give you 3 options: Europe' Japan, and America. Choose one. After that you will be prompted; "Do you want to continue?" Click "Yes" and you should be all set! Good luck!
SOURCE: The disc's region code is incorrect for this
Hi, kindly get the code here :
www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__rtgf
SOURCE: how can i make it stop saying 'the discs region code is incorrect
Best Regards, Jay__r45f4
