SOURCE: SPRINT SANYO PRO 700
Hey! I just got the PRO 700. IT DOES NOT USE SIM CARDS! instead like the other sprint phones it uses the ESN/MEID number on the back. Just call sprint and tell them you want to do an ESN SWAP or SWITCH TO A NEW PHONE and they will ask you for the number under the battery. They will also walk you through activating everything including Direct Connect. It is as fast as Nextel traditional Direct Connect but it has a MUCH LARGER COVERAGE AREA FOR VOICE AND DIRECT CONNECT. Soon these phones will take control and the whole IDEN network Nextel uses will be converted to CDMA (sprints High Speed Network).
SOURCE: can I used this phone
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
SOURCE: My battery life on my Sanyo Pro 700 doesn't last
may be but most probably ur ic may be damaged.....
SOURCE: Sprint told me to remove the SIM card from a Sanyo
The Sanyo PRO-700 is like all Sprint phones and uses the CMDA network so no Sim card is used. You can take the phone to the Sprint store and have the clerk's use the transfer machine and that should delete the duplicate entries.
Testimonial: "Thanks for your help."
