you buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
More Memory Equals - More Speed for your APPSThe
Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots,
that allows you to add more memory to your Toshiba Satellite A75-S211
Memory RAM, giving you enhanced performance and speed. You will see the
Immediate speed increase in your computers performance.
Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
We work directly with our memory card manufacturer to insure perfect
compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only
using the highest quality memory chipsets for our memory cards, so you
are assured compatibility and performance. All of our memory cards are
Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM .
Technical specialists have personally verified our memory cards
Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
Desktops
- Unplug Power cable
- Remove Case
- Slide memory card in Open slots- the memory card will only fit in one way
- Snap the side clips in place
- Close Case and Power Up
- You are ready to go.
Laptop
- unplug and remove Battery from laptop
- Open memory compartment on bottom using Philips screw driver
- inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
- Close compartment and power up you are off and running.
There are two common problems with the A75. First off, check to see when you wiggle the AC adapter around if the power light flickers, if so then the DC jack on the board is going out and needs to be resoldered/replaced. Second the heatsink gets clogged on this model and needs to be cleaned out regularly. You can use an air compressor and shoot air through the two fan spots on the bottom towards the back of the machine to get some of this out. (can of air is not strong enough) Make sure the machine is off and the battery is out. It isn't really that good for your fans so don't overkill it.
