My maytag neptune electric dryer will not work the control panel lights are on but i push the start button it doesnt do anything it doesnt beep or anything
Owner's manual? Troubleshooting section. Customer service call. They are usually helpful. Wild guess, problem with the gas supply. Could be lower than normal gas pressure because of the high demand in cold weather. Could also be a similar electrical voltage lower than normal. The "brains" in appliances are too smart sometimes.
inside the control panel is a tech sheet that has some diagnostics on it . there is a membrane button test or something to that effect. I suspect that the start/pause button is the problem and you would need to replace the console w/touchpad.about $130-140 new. there are some used ones on ebay.
pf means power failure. your dryer uses an extra boost of power on start-up and your is failing to get this boost you need a repair person in your area
yes got 240 coming in
