Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
Posted on Nov 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore elite refrigerator alarm keeps going off even though the doors are closed
Chris Huff
Level 3:
Top Expert:
  • Kenmore Master 6,289 Answers
  • Posted on Nov 06, 2018
Chris Huff
Kenmore Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2017793
Points
74913
Possible door switch problem
Sal De
Level 3:
  • Kenmore Master 2,699 Answers
  • Posted on Nov 21, 2009
Sal  De
Kenmore Master
Level 3:
Answers
2699
Questions
0
Helped
1002366
Points
8029
You have to send model number,on some bottom mounts there is a metal striker on the door that hits the switches,sometime that gets bent back,all you have to do is readjust the striker by bending it if screws aren't loose but i don't know what kind of bottom mount you have
  • 1 more comment
  • Sal De Nov 25, 2009
    try unplugging the fridge for 5 to 10 minutes to reset board.or try this
    Press and hold the "Lock/Alarm" button on the control panel until the indicator light turns off. This shuts off the door alarm and it will not beep if the refrigerator doors are left open.
    Reactivate the alarm by pressing and holding the "Lock/Alarm" button until the indicator light turns on.
    send model number
  • Sal De Nov 26, 2009
    try tilting fridge back by adjusting front legs up so doors close better,also i guess this is a problem with this fridge,i looked it up online and some people have changed computer board to fix this and others had to call factory and swap fridge for a new one,i'd call the factory first to see about any recalls and see who does thier warranty work in your area
  • Shane banholzer
    Shane banholzer Nov 06, 2018
    This is my model number is the first thing an option 795.7209
How to make the freezer door on a kenmore elite 74033 tilt
Refrig of the year: Kenmore Elite 74033 Refrigerator
Consumer Reports Rated: Excellent
Hello Charles,
Just when I'm thinking Sears SERVICE is NOT some sort
of sad/bad joke... you put in a Kenmore Elite Model number...
continued search found your Owners Manual... Pages 10 & 16 are what you want
The front should be slightly higher than the rear to aid in door closing... (page 10)
Your refrigerator has two front leveling legs-one on the right and one on the left. Adjust the legs to alter the tilt from front-to-back or side-to-side. If your refrigerator seems unsteady, or you want the doors to close more easily, adjust the refrigerator's tilt using the instructions below: NOTE: Tools Required: 11/16" wrench or flat blade screwdriver.
1. Turn the leveling leg to the left to raise that side of the refrigerator or to the right to lower it. It may take several turns of the leveling leg to adjust the tilt of the refrigerator.
NOTE: Having someone push backward against the top of the refrigerator takes some weight off of the leveling legs. This makes it easier to adjust the legs.
2. Open both doors again and check to make sure that they close easily. If the doors do not close easily, tilt the refrigerator slightly more to the rear by turning both leveling legs to the left. It may take several more turns, and you should turn both leveling legs the same amount... (page 16)
`` After that...
All you have to do to maximize that efficiency is keep the closure area free of pizza boxes, ice cubes or errant frozen food bags.
Hope this was helpful...
Kenmore Elite 74033 Refrigerator Review Kenmore com
2answers
How can I turn the door alarm off in my samsung fridge?
the alarm indicate that the door is open
check the door switch and check if the door press the switch or not
I think the door latch didn't reach the switch
1helpful
2answers
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
2answers
Alarm no longer sounds when fridge door is open
Chances are that you will have to replace the buzzer. That part is available at Sears Direct. J
3answers
Lights will not go out when I close Kenmore elite refrigerator
Hello John, the door switch is stuck in the on position. It may be possible to lubricate it with a squirt of PAM cooking spray, or it may have to be replaced.
Freezer door not sealing
replace the seals and / or have the hinge adjusted
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
