The baja is gasoline powered car.
if it lacks power the fault may be internally in the engine.
clean airfilter
check throttle linkage
set high an low speed needles to factory setting.(refer to manual for correct setting)
ADJUST IDLE
check carburetor.
check all fuel lines and mix ratio of fuel and 2-stroke oil.
check spark plug and spark plug wire and cap.
if you open up the engine yourself check all gaskets an seals
(if you dont know how to split the engine get a hobbyshop to check it out for you)
if the engine is old u might have to replace piston rings to get the compresion rate up again.
check your exhaust.
THIS IS A FAIRLY ADVANCED VEHICLE SO THERE IS MORE THAN ONE POSSIBILITY FOR THE ENGINE TO LACK POWER.
AND THERE IS NO EASY WAY OF FINDING OUT EITHER.
Replace batterys or charge them.
