Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
Drill sometimes the drill dont work when i press the button until i shake it vigorously
  • Anonymous May 27, 2008
    WHEN I PUSH ON THE TRIGER MOST OF THE TIME IT DOES NOT WORK
  • jon perry May 16, 2009
    i have a dewalt dc920 xrp 18v drill and it doesnt work unless i shake it.ive changed the brushes and adjusted the battery connections.
    Problem Solver:
  • 14 Answers
Hi hope to help
sounds like you have a problem with your brushes they may just need replacing but do not strip the drill down to do this just take out the batery then take the 4 screws from the rear off the drill and take off the cover see if the brushes are worn it doesnt take a lot of wear to be worn.
You can take off the wire from each brush unit then use a small flat screwdriver to pop out the brush unit then replace you should be able to get the brushes from any dewalt stockest.
Hope that helps. Sean
Posted on Mar 04, 2008
    Champion:
  • 313 Answers
I guess switch problem
Posted on May 28, 2008
6ya staff
SOURCE:
How do you clean a Stanley mug lid??
How to Clean Stainless Steel Coffee Mug Hunker
However from Stanley:
You'll need:
  • ¼ cup uncooked rice
  • 3oz distilled white vinegar
Instructions:
  1. Pour ¼ cup of uncooked rice into flask.
  2. Fill flask with 3oz of distilled white vinegar.
  3. Seal flask.
  4. Shake vigorously for 1 minute.
  5. Let sit for 5-10 minutes.*
  6. Shake vigorously again for 1-2 minutes.
  7. Empty flask. Bonus points for composting the rice.
  8. Rinse thoroughly with warm water.
  9. Leave open until dry.
How to properly clean your Stanley products
Jan 11, 2018 | Coffee Makers & Espresso Machines
My Ryobi PD750 impact drill just stopped working! Is there a safety button or something that could prevent it from working? Ive tried other plugs. Its fairly new.
The wires on the brushes sometimes shake loose , tool repair shop ,, or try it yourself ,, remember. Small parts ,, take pictures , tiny wires , may need to be soldered back in place ...
Jun 11, 2017 | Ryobi Drills
Faulty bosch hammer drill
a bad trigger switch; bosch sells a replacement part
Jul 24, 2010 | Bosch Drills
Uhh....... the blender mafuntioned when i plug in it blens even when i dont turn it on
Sounds to be a switch is stuck or button . Tap each button vigorously and turn each one on and off. Pressing another speed should cancel what ever button is stuck. Good Luck, Ned
Sep 27, 2009 | Sunbeam 4192 Work Top Blender
MY 92 CUTLASS AFTER 20 MINUTES STARTS SHAKING VIGOROUSLY THEN DIES AND WONT RESTART UNTIL IT COOLS DOWN 20 OR MORE MINUTES THEN STARTS RIGHT BACK UP
if a temp. light does not come on and the engine is not over heating I would look into the ignition components such as ignition module inside the distributor, sometimes when these components heat up they can cause this problem you described
Jul 03, 2009 | 1998 Oldsmobile Cutlass
Drill doesnt work unless shaken
It sounds like a bad cord, or a loose electrical connection inside the handle, or the switch.
Instead of shaking the drill, try wiggling the cord where it goes into the drill handle, then wiggle it where if plugs into the wall.
If this doesn't cause the drill to run, try pressing the switch repeatedly to see if that causes it to run. If that doesn't work, it's probably a connection inside the handle.
Try these procedures and please let me know the results. We'll take it from there.
thanks...
Charlie
May 09, 2009 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
Shake the drill to make it work
Sounds like the battery is not making a good connection inside the drill handle. Clean the contacts inside the handle where the battery plugs. Clean the contacts on the battery. If there are any springy tabs in either of these places, pry them up slightly to increase the pressure between the contacts.
Clean with wire brush, sandpaper, electrical contact cleaner.
If this doesn't work, get back to me and we'll go to the next step.
Charlie
May 09, 2009 | Dewalt DC925 Cordless Drill
I just replaced the switch assembly for the same problem
Jan 12, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
450 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Lance Guthrie
Lance Guthrie
Level 1 Expert
Spud Howell
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
