When the bucket is full the arm is up the maker is off.
If the ice maker has a on/off button in off the ice maker is off
If the ice maker internal heater fails the cubes will not release and the white plastic ejector arms will be rotated CCW and pressing against the ice in the tray, Normal position for ejector arms is vertical.
If water solenoid has failed or water supply not available the ice maker will cycle. The ice tray will be empty,(hard to see if ice tray is empty). Check and replace water fill solenoid.
If ice in tray and ejector arms vertical several possibilities.
Freezer not cold enough to trip thermostat in ice maker to initiate release cycle.
Check freezer temperature <10 Fahrenheit thermostat in ice maker failure
The best way to check the operation is to manually lock the arm up into the off retention position. Wait a minimum of one hour. Open door and release arm down. Observe the operation of the ice maker. Is after a minute or so the ejector arm does not rotate then it is likely the ice maker has failed internally. If the ejector turns and no ice than you can assume either the water supply is off external from the refrigerator or more likely the water solenoid located behind the bottom back cover has failed. It is also possible that the hose that connects the solenoid to the ice maker has frozen right where it enters the freezer just above the ice maker. You should see ice built up at the entrance where the water fills the tray if this has occurred.
it may take a while for your fridge to cool down that water again. if this happened in the last half hour or so. im guessing your fridge may take upto an hour to drop a load of ice.. this also depends on the ambient temperature
before you figure it's out of freon- there are coil cleaners you can get at a air condition contractor store. you should clean both the inside and outside coils. make sure both fans are running (in & out)
I bought one new, and it had a great recipe for Kiwi fruit ice cream, using kiwi fruit and oranges. I can't find the recipe book. You make just over 1 l of fluid ice cream mixture, the bowl must be pre=frozen for at least 15 hours, just put the liquid in the machine and crank the handle in quarter turns (the square outer box helps measure this!) every 5 min for the first 30 min, and then half turns every half hour or so.
Your television is going to require internal repair. if you are comfortable making internal repairs yourself then please use our premium service for assistance. If you do not feel comfortable with making the internal repair yourself, please use the Repair Service search engine on this site to help you find a local repair service.
Thanks,
Vanilla Bean Ice Cream makes 1 generous quart
4 egg yolks 2/3 cup sugar 2 cups half-and-half 1 vanilla bean or 2 teaspoons vanilla extract 1 cup whipping cream
In a bowl, beat the egg yolks until blended and mix in sugar. Heat the half and half, stir into the egg yolks, and pour into the top part of a double boiler. Split the vanilla bean and scrape its seeds into the cream and add the bean as well. Place over simmering water and stirring constantly, cook until the mixture is custard-like and coats the spoon. Remove from heat and refrigerate until cold, or several hours. Remove vanilla bean. If using vanilla extract, stir it in at this point. Just before ready to churn; stir in the whipping cream. Freeze according to directions for your ice cream freezer.
Make sure coils and filter are clean. If you still have the problem it is probably low on refrigerant or the fan is not running.
