Check and make sure the outside fan is running. The KSR series Kelvinators were rebadged LG units. It is possible the 6uf fan capacitor on the outside unit has failed.
my home outside ac unit isn't blowing out any air the coils are clean yet for some reason the freon leaks out from the base out to the pipe. what seems to be the problem amd how can I fix this
Please write how many times blinking and with an interval. Depends upon it, we can give solution.
Normally, blinking 5 times means for drain motor malfunctioning. Check drainline, oif blocked clean it. If drain motor not working, replace it. If blinking 2 times, Indoor room air thermistor defective replace.
Out door compressor getting over heated. Check freon pressure. May be short of gas. If fan motor less rpm, replace capacitor. If condenser dust blocked,m clean it.
you may want to do a search on the dell website, i had that problem and never fixed it, you might find the information under service manuals search.
good luck.
Ok , most of the time this would be the Fan.Powerboard that is faulty then and unfortunatelly it would be better to replace the part rather than having it repaired.
Repaired Powerboards normally give the same problem a couple of months down the line.
