My eltax avr-200 is having a strange problem, there is no output it turns on all the lights are on but there is no output. one of the speaker levels is on max and i cant get it to move is this the problem? if it is how do i fix it. the relay clicks in after a few seconds after turning on so thats not the problem any help would be much appreciated
thanks
Eltax AVR-200 will start up in protection mode if the amplifer went into protection mode due to high volume before it was turned OFF and it will start at the same volume level as it had before power OFF.
To correct this you must shift to another input without signal, then turn the volume down before it goes into protection mode again.
I have tried this but as soon as i change to the input with signal and turn up the volume the speaker level goes to max again is there any other way of fixing this?
